Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 36
Thread: p plate engine conversion?
  1. #21
    Veteran ae86's Avatar
    Western Suburbs
    oh yes no such thing, shouldnt worry about p plates or your car getting auctioned off after 3rd impound, i was just joshing everyone about engine conversion i must have been having a nightmare, called reality.
  2. #22
    Jay
    Just to clear this up if you are in Victoria and are not under the old power to weight P plate laws which were before july 2007 then you are unable legally to have any sort of engine modification to your car. This means even having a different type of filter IE ram flow on a 4ac infringes on this law, Red plates are in the same boat only they would be worse as they can now be specifically target as they stand out alot more then greens because there are still a heap of people on the pre july 2007 laws.
    I got my p in 2008 before the red p plate laws came into effect and I know I cant have any engine modifications legally, though you could most probably pass a 4age as stock to the relevent authorities you can still get done for it.
    Also just think of the insurance side of things , if you had a big accident and they found out that you had change your engine you can get into serious shit because of it as they will probably try to not pay for any damaged you do to your car or other cars depending on what happens.
    As for the factory option case this is true but untill it is proven properly that toyota did bring in the mythical 41 jdm ae86's and that information is submitted to vic roads / other state road offices then we cant do much.
  3. #23
    Quoted from the RTA NSW
    Prohibited vehicles
    The prohibited vehicle condition restricts provisional (P1 and P2) drivers from driving certain high performance vehicles. The condition applies to provisional licences issued on or after 11 July 2005. The scheme aims to prohibit young driver access to vehicles that are overrepresented in young driver crashes.
    Prohibited vehicles are those with:
    Eight or more cylinders (except diesel).
    A turbocharged engine (except diesel).
    A supercharged engine (except diesel).
    Engine performance modifications that require an engineers' certificate.
    Certain high performance six cylinder engine vehicles or other vehicles as described in the publication Novice Drivers - High Performance Vehicle Restrictions.
    put that in your pipe and smoke it.
    Technically a 16v requires only a blue slip i believe to change the associated engine number.
    Using the same block (4a) and no significant increase in power is seen as an "owners certified modification" as long as all the factory emissions gear is retained.
    Even better if you can show 41 4age AE86's were delivered.
    So technically, if you can modify the engine, suspension (lowered springs) muffler ect, as long as its an owners certified mod in realation to this:
    Owner-certified modifications
    Owner-certified modifications are generally those modifications which were optional equipment to the vehicle concerned. Owner-certified modifications also include some non-standard modifications of a minor nature which do not affect the level of safety, strength, or reliability of vital systems such as brakes and steering. These modifications have little or no impact on the vehicle's level of compliance with the Australian Design Rules. The modified vehicle must be presented to an AUVIS or HVAIS. For more information, see Vehicle Standards.
    and linked further to
    Do I need an engineering signatory for minor modifications?
    Vehicle modifications fall into three distinct categories:
    ‘Owner certified’ minor modifications which can be accepted for registration purposes without formal
    certification.
    ‘Engineering signatory certified’ modified production vehicles.
    ‘Engineering signatory certified’ individually constructed vehicles.
    Owners certified further clarified as:
    Owner certified minor modifications are generally those modifications which were optional equipment for the vehicle
    concerned. Owner certified modifications also include some non-standard modifications of a minor nature which do
    not affect the level of safety, strength or reliability of vital systems such as brakes and steering. These modifications have
    little or no impact upon the vehicle’s level of compliance with the Australian Design Rules.
    Examples of minor (owner certified) modifications are:
    Engine changes where the capacity increase is less than 15% above the maximum size engine available for the
    vehicle (providing no major structural modifications are necessary and where noise and/or exhaust emission
    ADRs apply, all standard equipment such as carburettors, exhaust systems, exhaust gas recirculating valves,
    oxygen sensors and catalytic convertors relating to noise and emission control are retained and operate
    correctly).
    The fitting of a proprietary sunroof (if the modifications are of a minor nature only).
    Fitting a ‘package’ available as optional equipment for the vehicle (eg front disc brakes, power steering, alternative
    transmission and bucket or bench seats).
    Additional lighting eg fog & driving lights.
    Alternative wheels and tyres within the owner certified limits set by the Authority (see Vehicle Standards
    Information Sheet No. 9 Guidelines for alternative wheels & tyres).
    Fitting of handling enhancing suspension components such as roll stabiliser bars and up-rated shock absorbers.
    Major modifications which fall outside the category of minor (owner certified) modifications require submission of
    certification by an RTA recognised
    Does the RTA require notification of the modifications?
    All major modifications must be reported to the RTA. Minor modifications made to the motor vehicle or its
    equipment which affect registration details must be reported to the RTA to ensure that accurate records are
    maintained. These details include engine number, engine capacity/motive power/number of cylinders, body shape,
    fittings, number of seating positions, unladen (tare) weight, gross vehicle mass, axle code, wheelbase & overall axle
    space. If the unladen weight has changed, the owner must provide a weighbridge ticket for the vehicle in its new
    configuration.
    Modifications are reported to the RTA by obtaining an Adjustment of Records and a ‘blue slip’ from an
    Authorised Unregistered Vehicle Inspection Station (AUVIS). For details of your nearest AUVIS contact the RTA’s
    Customer Service Centre on 13 22 13.
    The Adjustment of Records, blue slip and any engineering certificate are then presented at a Motor Registry. The
    owners copy of the engineering certificate is stamped and endorsed by the RTA and must be kept in the vehicle.
    This certificate must be presented to an authorised officer of the RTA or the police when requested.
    To what extent can I modify my vehicle?
    Engine modification
    1. Original engine modified
    Modifications to the original engine are permitted provided the following conditions are met:
    �� Normal engine reconditioning within manufacturer’s limits is permitted;
    �� Modifications must not affect compliance with any emission or noise related ADRs;
    �� All emission control equipment must be retained and functional;
    �� If the modifications result in a substantial increase in power, then the adequacy of other components to
    carry the increased power (brake performance, vehicle controllability, suspension systems,
    Please note that under no circumstances does it say that the engine your swapping to had to be available within Australia, just that it doesnt change the maximum AVAILABLE size for the car..... and since its the same size, your in like Flynn
    vehicle
  4. #24
    i would advise that the RTA pamphlet is an abbreviation of the legislation for the state.
    if someone can point out legislation to contradict what i have referenced from the RTA i would say that, from a defect standpoint, your sweet as long as your follow the guidelines from the RTA, seeming as they are the authourity when it come to the road rules.... cops are just there to carry out the rules that the RTA write down
  5. #25
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Very good post Dave, that is all the crap I trawled through also.
  6. #26
    thanks.... i tried to search the legislation but nothing came up..... doesnt mean its not there, just that its hard to find.... cause it depends on the terminology they use in the legislation..
    interesting note, cars less than 3.5tn and exhausts lower to ground than 150mm pre July 1983 cars have a exhaust sound reading of 92db, while cars made after that are 89db, and it makes no mention of engine date, it goes by car build date
  7. #27
    Mt Macedon
    Nice research Dave.
    Just note that it is NSW specific. In Vic there is a clause about engine swaps don't need an engineers if the motor came out in the same chassis IN AUSTRALIA. Sorry not to be able to give a link for people, but it was in the Vicroads documentation last time I checked.
  8. #28
    Paul
    Maidstone
    i would say you can drive a 4age in vic on red p as it did state that no mods eg superchager or turbo !!! so till i get my ae71 happen well i will just stay with that !!!!! + get a 4age n drop it in after reg n rwc are done
  9. #29
    Mt Macedon
    ^^ Love your logic. That'll destroy everything in court.
  10. #30
    Andrew
    PS. I shagged your mum........your worship.
  1. WTB adaptor plate W5X TO T50 or hole conversion
    By _wanna-be_ in forum Cars or Parts Wanted
    Last Post: 5th July 2012, 08:31 PM
  2. Sandwich plate/engine end plate info needed 4AGE
    By killar_of_giants in forum Technical - Questions
    Last Post: 11th February 2011, 02:14 PM
  3. whats this engine mount plate do?
    By Sam-Q in forum Technical - Questions
    Last Post: 25th November 2009, 10:05 PM
  4. wtb engine plate
    By Nexx86 in forum Cars or Parts Wanted
    Last Post: 19th March 2008, 10:28 PM
  5. Mod plate for engine..
    By Nexx86 in forum Technical - Questions
    Last Post: 30th July 2007, 08:35 PM
