pics up
the sr is a red top. sold as is. the turbo shit a thrust bearing. owner before last heard the noise and thought the bottom end was gone. has been inspected by an experienced SR guy and everything looks to be ok. crank isnt scored, no spun bearings etc.
have brand new acl race main and big ends to go with it. i had every intention of installing these and full confidence in it being a good working engine.
has an engine loom, AFM, cas, injectors, NO COIL packs, no igniter. i had planned to use toyota COP ignition which can quite easily be made to work with the stock ecu.
s15 flywheel and clutch in good condition (barely used, has a lot of surface rust on the outside of the clutch cover though)
another turbo and manifold is included that looks to be in good condition
also a broken (well un checked) sr gearbox. this was bought separately. was just going to use it for the bell housing as i planned to use an RB box for the better shifter position.
also included is a radiator to suit this engine in an 86 (late celica GT4 type)
all of this together for $800.
78's
pics up
78's
wheels sold. bump.
78's
SR still here, make an offer![]()
78's
pm'ed
FUUUUUUUU thats cheap, if only I was in the good books with my money tree!
