Results 1 to 10 of 18
Thread: my wheel bearings hate me!
    Member shaunpierre's Avatar
    shaunpierre
    melb
    Default my wheel bearings hate me!
    more dramas with the sev.... driving me insane!!
    i got ae86 struts xt130 lca ect and my left front wheel bearings keep blowing... i replaced them sooo many times but they just keep blowing.. followed a owners manual with a toqrue wrench but no luck, filling hub right up with grease but no luck my stub isnt bad small evidence of scuff/wear on the outer side but no play so could it be the hub?? the cones are easy to insert and remove
    or should i look into gettin new stub and hub!
    people say rims and camber are a factor.. i dont think but i have 14x7.5 -7? and T3 canber plates but only on half way to max camber... ALSO my tyre wears soo much faster on the outer side.. it should be the opposite with the camber set up i got
    get back to me guys
    muzzers dont know bout my kpgc10
    Moderator Sam-Q's Avatar
    Endeavour Hills
    your using a torque wrench on wheel bearings?
    they are meant to be just nipped up with your fingers alone. Just curious what spec do they say?
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Go get a proper wheel allignment.. if you're running camber you shouldn't be wearing the outside of the tyre.
    Negative offset will of course kill wheel bearings quicker. I've gone through a couple on my ke70 (14x8 -15 xt130's etc)
    Glenn
    North Ringwood
    sound s like to much toe out ra40 struts for the win
    Jacob
    Sunshine Coast
    Why ra40 struts ftw if it's just a toe out issue? wheel allignment and it's fixed..
    Veteran Skylar's Avatar
    Ken
    bigger stub axles, bigger bearings, takes more load = run more negative offset?
    there is a torque specified in the ae86 chassis manual of 21Ft/lb.
    to the OP are you packing them with grease properly? not just smearing the grease over it.
    like shown here,
    you shoudltn have the dramas you are having, even with a bit of negative camber.
    - Blaise Pascal
    shaunpierre
    melb
    yea 30 newton meters, then undo and then finger tight, yeee packed the bearigns also, might get wheel alingment thats the cheapest option for now..
    thanks guys will update soon
    Member Philbo's Avatar
    Phil
    NT
    Darwin
    Mega toe in? Does it pull off the road/steer funny?
    Quote Originally Posted by Tim.duncan View Post
    Will you post #4 piston and the centre bearing from the turbo to broom?
    Glenn
    North Ringwood
    most full on race cars as in ae86 group A has a spacer made up to go over the stub axle to give it strength and some others went for the RA 40 strut as it had a stronger stub axle no flex like the ae86
  1. rear wheel bearings and seals
    By lach in forum Perth & WA Events and Discussion
    Last Post: 29th October 2011, 05:47 PM
  2. wheel bearings
    By fergie in forum General Topics (No Technical Questions)
    Last Post: 25th August 2010, 10:37 PM
  3. Wheel bearings
    By daz in forum Technical - Questions
    Last Post: 17th April 2008, 10:57 PM
  4. Changing wheel bearings ?
    By jase ek in forum Technical - Questions
    Last Post: 7th August 2007, 11:34 PM
  5. Wheel Bearings and stuff
    By MINIHORSE in forum General Topics (No Technical Questions)
    Last Post: 28th May 2005, 04:18 PM
