Results 1 to 10 of 11
Thread: WTB ae86 coilover front pair, must be height adjustable.
    Senior Member zookieboi's Avatar
    Gold coast
    Default Wtb: Jdm brake setup+ coilovers (fronts)
    Done some research basically want jdm front calipers. brake lines, rotors, coilovers with a decent set of shocks. Dont need top hats unless you have te27 camber tops. Needle in a haystack don't need needle.
    Located on the gold coast.
    0426233585
    Clutch Droppin Daddies. No questions.... Its just how we roll
    Jake
    Northgate
    Aren't all coilovers height adjustable? well not factory coil over stut, BC coilovers are base hieght adjustable and have the adjustable spring perch as well.
    Gold coast
    Not sure man, just after a pair of cheap second handies.
    Veteran AJPS's Avatar
    Lonsdale
    can make some for you if you have ae86 struts
    Gold coast
    Nah I don't it's actually a ke20, and I've got some te27 steering arms which allow you to upgrade to 86 springs.
    Lonsdale
    86 struts or springs?
    Gold coast
    Sorry, struts. It changes the bolt spacing and suits the 86 bolt pattern.
    Gold coast
    Dead keen to get a pair by next week.
    Gold coast
    Bump
    Senior Member Patric's Avatar
    Patric
    Enfield
    I have a set of JIC Magic Coil overs off Japanese trueno.
    Struts, tokiko short stroke inserts, springs, discs, brackets. Use your own strut tops. If you want a pic, I can take one this weekend.
    $650 plus whatever post is to your state.
    Silver 86 Trueno Hatch.
    AE86 4age gear for sale - http://www.ae86drivingclub.com.au/fo...eats-Ae86-gear
    Side intrusion bars for your import - http://www.ae86drivingclub.com.au/fo...our-JDM-import
  1. WTB 10kg Coilover Springs 65id 160mm free height
    By sumfancyname in forum Cars or Parts Wanted
    Last Post: 28th November 2010, 10:47 AM
  2. Replies: 0
    Last Post: 18th September 2010, 01:50 AM
  3. VIC: s13 silkroad coilover front pair
    By marioman in forum Car Parts For Sale
    Last Post: 20th August 2009, 09:39 AM
  4. Measuring Coilover Ride Height
    By Dave in forum Technical - Questions
    Last Post: 1st February 2009, 01:10 PM
  5. koni height adjustable platforms,
    By AE86GZE in forum Car Parts For Sale
    Last Post: 16th March 2007, 09:44 PM
