Are you using standard 20v loom or microleb loom.... When i changed an aftermarket ecu i just swapped everything at the ecu end.
B/Top pinouts for the ecu can be found here
Silvertop / Blacktop dizzys are the same, and the silvertop pinouts can be found here
Can do also do a continuity test when i get home and upload a pic of the dizzy plug if that is easier?
