Results 1 to 6 of 6
Thread: Whats needed for T series diff into ADM AE86
    Junior Member BARWICK's Avatar
    Aug 2011
    Barwick
    Touge
    Default Whats needed for T series diff into ADM AE86
    Hi Guys,
    I will be picking up my JDM AE86 T series diff soon and Im trying to find out what modification is required to make it fit in my ADM sprinter.
    1) I understand that you need to replace the rear tailshaft with a 20mm shorther tail shaft from either a JDM AE86 or T18. Is there any other cars that run this 20mm shorther tail shaft?
    2) Can you use the standard handbrake cable from a s series diff?
    3)My new diff will have disc brakes (old diff has drums) will I need to upgrade the master dylinder or brake booster?
    These are just some things I thought of, please let me know any other moddifications required.
    Kind regards
    Senior Member bones's Avatar
    Apr 2010
    Brandon
    Geelong
    edit, didnt read full post
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Hi
    When running disc brake you need to use the JDM disc brake handbrake cables , not the s series drums ( I have in stock)
    You need to change the brake bias to the rear disc via either fitting the JDM valve and T - Piece in place of the 1 piece adm valve assy or some people gut 1 part of the adm valve so as to get less brake pressure to the rear discs , BUT NOT Recommended.
    Master cyclinder and brake booster is the same.
    Yes you need either a T18 rear section of the tailshaft or a whole AE86 JDM tail shaft assy. ( Have in stock)
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
    Aug 2011
    Barwick
    Touge
    Hi 44ATE,
    What are your prices on the below and cost of postage to SA?
    JDM disc brake hand brake cable
    JDM tail shaft ass.
    Thanks for your help.
    Kind regards
    Jason
    Gold Coast
    Oh, I thought the problem with the adm brake bias valve was that it wasn't letting enough pressure to the rears, so its actually letting to much, is that right?
    also anyone used a willwood bias adjuster to get around this problem? any info on the product?
    Aug 2010
    Geoff
    mt dandenong
    so just clearing up if your going to put a t series drum setup in to a 86 currently fitted with a s series do you have to change handbrake cables too? or are they both the same
  1. NEEDED: T SERIES DIFF
    By Gunner in forum Cars or Parts Wanted
    Last Post: 9th January 2013, 02:23 AM
  2. ae86 adm s series diff drum to drum
    By jasonae86 in forum Car Parts For Sale
    Last Post: 10th October 2012, 12:31 PM
  3. Replies: 0
    Last Post: 1st July 2012, 01:36 PM
  4. S series diff or axel needed ASAP! SA!
    By Ham86 in forum Cars or Parts Wanted
    Last Post: 1st September 2011, 10:53 PM
  5. f series diff centre needed
    By hks-to4r in forum Cars or Parts Wanted
    Last Post: 24th May 2009, 11:36 PM
Tags for this Thread
