Results 1 to 10 of 17
Thread: Help needed with T3 big brake kit!
    Junior Member brutus's Avatar
    Mar 2011
    Gerhard
    Forrestfield
    Default Help needed with T3 big brake kit!
    Hi guys.
    I spent most of the weekend fitting my BC coilovers, T3 big brake kit, T3 lower control arms, brand new Ae86 hubs from Toyota and tie rod ends and polyurathane bushes to my Ae71 corolla. The problem is that the rotors sit too close to the brake caliper bracket and I can't even get the alloy T3 bracket mounted. There just does not seem to be enough space. I know a few of you has fitted this brake kit. Can anyone give me any advise please?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    arn't they made for ae86 struts?
    Mar 2011
    Gerhard
    Forrestfield
    Yeah mate the BC coilovers are for an Ae86. That's why I can't figure out what's going on.
    West
    The bracket goes on the other side of the stock caliper bracket.
    West
    Heres how it should look...Click image for larger version.
Name:	bigsucka brakes.jpg
    Mar 2011
    Gerhard
    Forrestfield
    That's how I've put it together but the rotor pushes against the alloy bracket before the hub is all the way home. From the picture it almost looks like your original calliper bracket is different to mine though.
    Endeavour Hills
    I don't know if your comment was sarcasm or not, but the struts are different
    Mar 2011
    Gerhard
    Forrestfield
    No sarcasm mate. Maybe just a bit unsure of what you're asking but everything I've bought so far is for Ae86. The struts, the brake kit, the lower control arms and tie rod ends as well as the hubs. I even tried to fit the brake kit on my ae71 spindles but it's almost the same outcome. I'm pretty sure my original brake calliper mounting plates does'nt look like the picture that little red spirit posted.
    Jake
    Northgate
    He has BC AE86 coilovers is what I think he is saying. Maybe you have the bracket on backwards?
    Endeavour Hills
    ah I see, odd
  1. Wilwood T3 AE86 Big Brake Kit
    By sundee in forum Spirited Drive
    Last Post: 11th November 2012, 10:41 AM
  2. T3 vs K-Sport vs FC brake conversions Opinions/Help needed
    By OMR510 in forum Technical - Questions
    Last Post: 25th August 2011, 05:21 PM
  3. Replies: 30
    Last Post: 13th August 2011, 02:37 AM
  4. FS: [SYD] Wilwood/T3 big brake kit (brand new)
    By willio in forum Car Parts For Sale
    Last Post: 11th May 2010, 06:33 PM
  5. any1 have t3 brake upgrade kit
    By nath in forum Technical - Questions
    Last Post: 29th April 2007, 05:52 PM
