Hey dude I replied to your thread on RC, I'll contact you tomorrow regarding the clutch setup. I want it but I'll have to quickly check something first.
I'm in Brisbane also.
Thanks,
Rian.
I have some bits to get rid of
AE71 hydraulic clutch setup
- manual pedal box
- master cyl
- hard line
- and pbr slave, no flex line SOLD
$250
AE71 engine crossmember
- with rack in g/c
- crossmember
- rubber mounts
- block mounts
- gearbox to block lower mounts SOLD
$200
4AGE BIGPORT cyl head with valves, no cams or gears
- looks ok condition
$50
4AGE cam covers
- painted blue but a few chips in the paint SOLD
$30
4AGE BIGPORT ecu
$50
4AGE exhaust manifold flange
- 10mm thick mild steel
$20
XT130 lca's
- bushes are gooooooone, arms are straight SOLD
$100
THE EVOROLLA
none of this SR shit . . . EVO 7 powered bitches
https://www.facebook.com/KeConversions
KE conversions - making your conversion simple
4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
Thanks,
Rian.
I'll take those LCAs off u if they are still there on Thursday I'm from Brisbane as well text me whenever let me know 0432161773
I still haven't figured out what I'm doing with my car, so you can ignore my above post.
Sorry man.
PM sent for clutch setup
Lets play . . . identify this head and ecu???
clutch pedal setup sold pending payment
THE EVOROLLA
Bigport.
ecu and head? out of curiosity how do you tell?
THE EVOROLLA
The number of pins per outlet on the ECU and the yellow colour tell you it's bigport. Grey colour plugs are smallport. The head is bigport too, it would be easy to tell if you had a smallport head next to it but you can tell it is bigport from the width of the ports. They're more elongated than smallport.
ok cheers for the info man
THE EVOROLLA
