Keen as, I'll call you when I finish work!
strut tube is based on an XT130 casing. these are the same bolt spacing as AE86 and so are compatible with all 86 steering knuckle options, but they use the bigger (much stronger and cheaper/more common) celica/supra/corona wheel bearing.
brakes are MA61 supra spec. disc size is 250x20mm will fit in a 14" rim. plenty of stopping power for a light 86, will easy be big enough to get your SR etc converted car past engineering.
inserts are short stroke GAZ gai adjustable, revalvable, rebuildable. they are 0klms, BRAND NEW.
sleeve kit is otomoto, 8kg springs with helpers.
struts have been shortened about 50mm. so will work with basically any insert. they also accept the latter type coarse thread/nissan type gland nut.
i have some spare AE86 power steering knuckles here i will chuck in with them.
price is $800.
this is a bargain everything is there, if youve got a ke/ae71 you can skip the whole find 86 struts/hubs/brakes/knuckles bullshit, all that is included.
pm me or call 0468 859 863. cheers.
78's
sold
78's
