Results 1 to 10 of 12
Thread: NA beams question
    Jul 2010
    Exclamation NA beams question
    i am looking to pick up a set of cams for my 3sge beams motor, just wondering.
    1. max size before vvti is canceled
    2. would the kelford spec A or B cams be better for drop in purpose with new valve spring retainers, tune etc.
    cheers guys
    also would be great if you could link me to any built beams engine to compare on how many kw's people are pushing.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    those kelford cams are for gen 3 3s engines, beams is gen 4 I think and the VVT is different? someone can correct me if I am wrong here
    Jul 2010
    yeah beams is gen 4 damm
    Jul 2010
    i guess toda, or i could become a test subject for kelford
    Veteran AJPS's Avatar
    Lonsdale
    do it
    Glenn
    North Ringwood
    as soon as you change cams with more lift and duration ,1 you will need to change valve springs and 2 not much vvti any more and 3 piston to valvbe gets closer
    and im pushing 200 kws at back wheels 2stage injection 50 mm quad throttles and 14.65mm of lift and 14.5 to 1 comp
    Jul 2010
    what is stage 2 injection, also what cams with the 14mm lift ?
    is this with just,new cams, adjustable pully's, new valve springs/retainers/valves, + tune ?
    thanks for the help really appreciate it
    Glenn
    North Ringwood
    its with forged pistons .longer forged rods for highrrpm now 9500rpm ,new steel valves new springs new retainers ,billet crank ,head work .50mm quad throttles 2 sets of injectors 500cc in head 1000 ccout in the 2stage injection big 12 litre air box plus 2 different sets of pipes and cams are billets as well ,every part is changed except block and this uses some vvti movement
    Senior Member shelldrake's Avatar
    Eddie
    Ripponlea
    Just wondering how this works, Sunday before last your car made 154.7 kw on the dyno and now it's pushing 200! Go figure.
    Mar 2011
    Dave
    SE suburbs
  1. 3sge beams conversion question, factory ecu
    By sundee in forum Technical - Questions
    Last Post: 26th May 2012, 02:20 AM
  2. Replies: 12
    Last Post: 29th November 2010, 09:00 AM
  3. BEAMS Question - Fuel rail fittings.
    By Touge Boy in forum Technical - Questions
    Last Post: 2nd July 2010, 08:47 PM
  4. hilux diff t50 and na bigport ANOTHER QUESTION ADDED
    By 350hp4agte in forum Technical - Questions
    Last Post: 13th December 2007, 05:44 PM
  5. na na na na na na na na na BATLEB!
    By snake in forum Offtopic Discussions
    Last Post: 8th November 2007, 10:05 PM
