Results 1 to 10 of 11
Thread: Nology High performance Ignition systems
    Gone
    Joel
    Picton
    Default Nology High performance Ignition systems
    SD Garage is Now an Authorised Distributer for Nology Ignition systems.
    Hotwires
    Cool wires
    Spark plugs (solid silver electrodes!)
    Stay tuned for prices.
    available for:
    4ag 16v
    4ag 20v
    3sge
    3sgte
    Veteran 70rolla's Avatar
    May 2010
    Tyler
    Sutherland Shire
    Joel how much for 16v jap bigport lead set need asap pm me
    Veteran slide86's Avatar
    Huw
    Hills
    You can see these being fitted to Keiichi's TRD AE86 in one of the Hot Version AE86 club dvds.
    Quality piece of kit.
    Gone
    Joel
    Picton
    They are going to be around $200 - $220 ish + $15 express post
    Sep 2009
    Rohan
    northshore
    How long would it take to get a set for a 20v?
    Gone
    Joel
    Picton
    none in stock atm.. havent had much interest in them... would atleast be a 6 week wait maybe more
    Sep 2009
    Rohan
    northshore
    ok fair enough what kind of power gain are you suppose to get out of these ?
    Gone
    Joel
    Picton
    here is some info for your reading
    they claim 5 - 10hp over the RPM range
    Senior Member Stain's Avatar
    Derek
    Far North
    As I was reading thru that... I was dubious, but it almost had me.
    Until I saw this:
    Now... let's say there is a 'gain' for using this on a standard dissy / coilpack setup.
    But removing your coil-on-plugs... which have a direction connection to your spark plugs...
    and adding half a metre of resistance is taking a step back 20 years!
    If this was such a good idea, you'd see it on Zondas, Astons, Ferarris... but you don't.
    Gone
    Joel
    Picton
    i do agree with you there stain... i think the above setup is a stupid idea... but look, the only real way we are going to know if these actually make a difference as claimed is to do some power runs on a dyno, one with stock leads and one with nology leads... its really the only way.
    BTW... that coil pack bracket looks like its home made with a nology sticker.... its warped, scratched and the bends are not even symetrical.. i think a monkey build this setup.. but hay i maybe wrong
  1. Bendix High Performance anti-squeal lubricant
    Last Post: 13th November 2012, 05:33 PM
  2. DBA High Performance Disc Rotors!
    By gslrallysport in forum GSL Rallysport
    Last Post: 5th October 2011, 10:17 AM
  3. Remsa High Performance Brand Pads!
    Last Post: 6th July 2011, 05:17 PM
  4. DMS High Performance Shocks and Coilovers!
    Last Post: 1st December 2010, 03:24 PM
  5. Koni High Performance Shock Absorbers!
    Last Post: 15th February 2009, 07:54 PM
