Results 1 to 10 of 13
Thread: Wierd timing issue...
    Dec 2010
    Jaidyn
    Burleigh Waters
    Unhappy Wierd timing issue...
    Car - KE70
    motor / part in question - 4AGE bigport
    problem - Timing retards itslef to ATDC, after cranking several times it will return to BTDC
    occurs/started when (if applicable)- Forever
    Basically my car has always had this starting problem, when starting the engine it runs really rough and mostly dies but after about 10 goes it finally fires up and drives like a dream
    But i cant work out what could do this, i have tested and retested every single sensor on the engine according to the blue book. My TPS needed replacing and i replaced that today $220! still nothing. However when checking my dizzy pickup coils sometimes they are in range and other times there out by about 4ohms and yes i know i should replace it but i have no job at the moment so i was hoping i could get a definite answer before buying.
    And i am positive it is firing ATDC because i have checked with a timing light
    Any help would be appreciated.
    Thanks
    Jaidyn
    Dec 2010
    Jaidyn
    Burleigh Waters
    Anyone?
    Veteran timbo's Avatar
    Tim?
    Wild West
    Is the TPS loom ok? Does sound very odd if you have replaced the TPS though... Maybe unplug it and crank the car over and see what timing it does.
    Aaron
    i have had something similar happen 3 times before. never on a 86 though.
    turned out to be the keyway on the crank gear had flogged out and causing the timing to fluctuate as the gear was shifting back and forth on the crank.
    Dec 2010
    Jaidyn
    Burleigh Waters
    Yeap TPS loom is fine, and keyway is also fine. It is something to do with the electronic ignition and i am 100% sure i know my dizzy needs replacing, but could comething like an ignitor also cause this?
    Tim?
    Wild West
    You have run a multimeter on the coil though haven't you?
    Pull the dizzy apart and have a look through google for some rebuild photo's, maybe the problem is the crank angle sensor, who knows... Does sound frustrating though!
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    Could this have something to do with the knock sensor? Or does a 4age bigport not have one?
    ADM AE86 Levin
    Tim?
    Wild West
    Bigports do not have a knock sensor.
    Dec 2010
    Jaidyn
    Burleigh Waters
    Well i havent got around to getting a dizzy as of yet and im just trying to live with it (unemployed :|) but lately when it hits 2000 revs when slwoing down it dies down and then does one really loud backfire and stalls. Ahh so frustrating could a coil cause this? because i think my coil may possibly be out aswell
    Dec 2010
    Jaidyn
    Burleigh Waters
    I just checked my dizzy, i seem to have a bit of play within the shaft itself could this even be the problem?
  1. Weird 4age timing issue
    By bennyq in forum Technical - Questions
    Last Post: 14th November 2011, 08:01 PM
  2. 4age bigport timing issue
    Last Post: 3rd September 2011, 10:39 PM
  3. wierd noise
    By Ke70alex in forum Technical - Questions
    Last Post: 10th February 2010, 10:26 AM
  4. 4age timing issue/ lack of power
    By 131-sam in forum Technical - Questions
    Last Post: 4th June 2008, 04:44 PM
  5. wierd noise
    By callum1 in forum Technical - Questions
    Last Post: 24th June 2007, 07:27 PM
