Results 1 to 9 of 9
Thread: surge tank thoughts
    Aug 2011
    luke
    qld
    gold coast
    Default surge tank thoughts
    hey all pretty new to the whole engine swapp thing,,,im putting a 4age into my 81 ke soon and im just making sure i have all the parts to make it happen..
    im wondering do i NEED a surge tank setup?
    if so wot has worked for you
    if not wot has worked for you
    cheers and sorry for asking such a novice question
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Moved to correct section.
    Veteran KurtHS's Avatar
    Kurt
    East Melb
    You don't NEED a surge tank but chances are you will get fuel surge if you're drifting your car with less than a quarter of a tank of fuel.
    Your options are either:
    A - Get a JDM AE86 fuel tank, these have baffles within the tank which prevent the fuel from sloshing around and your engine potentially getting a big gulp of air instead of fuel.
    B - Run a surge tank, here's a good article that will give you some insight . Now with a surge tank you can go in car, ie in the spare wheel well or just in the boot, or you can go undercar. Undercar is what I have and what I prefer, it's cleaner, you don't have fuel exposed to the cabin and you don't get fumes in the cabin, having an undercar in a Corolla would require you to either find one of the specifically made undercar surge tanks that Aaron had made or find/modify one that fits yourself.
    I'm not making any assumptions but if you're not confident that you can do a grouse job of a surge tank I'd recommend just paying for a JDM 86 tank, a surge tank is one thing that HAS to be done right and not dodged up IMO. By the time you buy a surge tank and all associated parts and tools you could buy a JDM tank anyway, it'll look cleaner under your car, it'll be quicker/easier and much safer compared to a dodgey surge setup.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    EFI hosing (8mm i beleive) and some 1/2"
    Tank>>>>LOW pressure pump (pick up pump, im usinga carby 4-6 PSI pump works fine)>>>>>>>>>>> surge tank>>>>>>>Main HIGH pressure pump(VL/VL turbo pumps work good and cheap)>>>>>> fuel lines (original ones along rail are fine)>>>>>Fuel filter>>>>> rail>>>>>return fuel line(original line is fine also)>>>>surge tank>>>> outlet top of surge tank>>>>> fuel tank
    Oct 2010
    Dogan
    Tulla
    You dont need a surge tank, all ive got is a low pressure vl pump in-tank going to the high presssure vl pump and ive never had any fuel surge problems since putting in a 4ag. İve driven with the fuel light coming on and never experienced surge.
    You dont need it, but its probabaly better if you do have one.
    Aug 2011
    luke
    qld
    gold coast
    cheers for the help guys
    Stern but now fucked off...
    May 2005
    Nick
    And also, it is spelt "what", not "wot"
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    dont need one and if not done correctly will cause more issues, 4ag will never suffer if you get surge will just cut out around corners, just keep ore than 1/4 in the tank
    AE86 THE BEST
    Michael
    Crimebrook 2749
    why go to offort to half ass it in then end, why do a fuel setup thats going to surge, blake(member) on here his surges its fucking homo, it will have 3/4 tank and still surge, i did a surege tank never had an issue, never had a surge, i hear my lift pump surge all the time though
  1. in tank fuel pump with inbuilt surge tank
    By NIZLAH in forum Car Parts For Sale
    Last Post: 18th September 2012, 08:43 PM
  2. Replies: 10
    Last Post: 30th May 2012, 07:46 PM
  3. for sale , surge tank, aus fuel tank, hood linning + more
    By hillclimb86 in forum Car Parts For Sale
    Last Post: 20th June 2007, 12:20 PM
  4. surge tank
    By blu 86 in forum Car Parts For Sale
    Last Post: 13th March 2007, 08:23 PM
