Results 1 to 5 of 5
Thread: starting the car
    Brandon
    Blackwater
    Default starting the car
    hey,
    having a lil problem with starting my car, its nothing major but can get annoying, so in the morning when i start the car it starts straight away but after i drive it to work and go back out at the end of my shift it takes ages to start it just cranks over but does still start ever time does anybody no what the problem could be?
    any help would be appriceated, i also did a quick forum search and nothing came up for this exact problem
    Veteran Rice86's Avatar
    Richard
    Liverpool
    Could be starter motor on it's way out, First check that..
    dose
    Veteran timbo's Avatar
    Tim?
    Wild West
    Been having the same issue. Starter is getting too hot, its the warmer weather for me. I added more heath shielding around the starter, heat wrapped my headers and added some ducting to push cool air from the front of the car to the underneath of the starter.
    Mark
    maybe where you park at work the fuel drains back out of the rail. try turning the key to on for a little bit before hitting start
    Similar issue on my old mans ae82 with a silvertop.... But i have NFI what it is.
    When cranking what does your tach read? Not sure if 500rpm is normal, but that is what my old man is getting.
    It might pay to also check that the FOC is wired right on yours, so the fuel pump is being powered whilst you are attempting to start.
  1. Car not starting
    By dehney in forum Technical - Questions
    Last Post: 22nd February 2011, 03:20 PM
  2. Car not starting, Going to burn it!!
    By tc-rolla in forum Technical - Questions
    Last Post: 13th August 2010, 01:55 PM
  3. Ke70 not starting :S
    By boris in forum Technical - Questions
    Last Post: 8th March 2008, 10:46 PM
  4. Issues with starting car
    By Ko Ko in forum Technical - Questions
    Last Post: 17th September 2007, 10:13 AM
  5. problem starting
    By noobae86 in forum Technical - Questions
    Last Post: 14th February 2007, 08:49 PM
