Results 1 to 3 of 3
Thread: wolf 2d + 4age?
    Jan 2011
    Mat
    SOUTH AUSTRALIA
    ADELAIDE
    Default wolf 2d + 4age?
    Hi,
    I know its a stupid question, but i have a 4age in a ke10 corolla that im planning on turboing.
    i need an aftermarket ecu to run it all, but im curious if an old 2d could run the 4age? im sure it would work for fuel seeing its fuel only but what options are there for ignition? i have a 2d sitting in my shed thats why im curious if i could use it..
    it may be a cheaper option than buying another ecu..
    once again, i know theyre not the best.. but they ran cars back in the day so i cant see why they cant run cars decent now..
    Mt Macedon
    Yes, it could run it, but it would be more trouble than it's worth.
    Look at the ignition options for 4AGEs running carbs (you'd be in the same boat for ignition) and you'll soon see that they are either: expensive and good, cheap and nasty, or the result of years of backyard tinkering. Even if you did it "properly" you'd end up with a fuel computer and a seperate ignition computer. Not a good plan.
    If you do it, do it properly and get a computer that does fuel and ignition, wasn't produced in the dark ages (requiring serial ports and a DOS laptop to adjust), is still supported, has good software and that people can tune.
    Jan 2011
    Mat
    SOUTH AUSTRALIA
    ADELAIDE
    well said... ill just keep on looking for something i can afford then..
    worked on a rotor well, but i suppose rotors and pistons are fairly different..
  1. Wolf 3D Vs Adaptronic
    By PRIMRK in forum Technical - Questions
    Last Post: 18th September 2010, 12:45 PM
  2. Replies: 5
    Last Post: 6th June 2010, 10:21 PM
  3. Wolf and T50 FS
    By Blown86 in forum Perth & WA Events and Discussion
    Last Post: 12th May 2009, 01:31 AM
  4. Motec VS Wolf 3D
    By naNto in forum Technical - Questions
    Last Post: 8th April 2008, 01:42 AM
