hi all, im currently in the process of doing a bigport 4age conversion in my 86.
its going slow but steady.
i was hoping someone could tell me exactly how i should wire up the electric fuel pump.
i got it from sprint autoparts, its made for a vl commo. that seems to be the way to go from what ive read?
anyways, from what i can understand i should install the pump, making sure it is lower than the fuel tank. Should i also replace the lines?
if so what type of lines should i use?
also, can someone help me identify what the plugs at the end of my 4age loom are?
it comes off the end of the loom, the square one is meant to earth to the coil im pretty sure. dunno what the other two are for tho however? :/
ps. i did search for the fuel line question but couldnt come up with any conclusive answers really.
