My 550$ of purchases....
Got these finished off finally, will be trial and error to see how they go.....another step closer to getting the body side of things done....
Engine has been dropped off to receive some machining and balancing and a few tweaks....
And these....shortened them alot, shorter then p/s arms. Will be interesting to see how they go.
Frontend is back together, ready to be dropped back onto the ground, still got to drop the cradle out and weld off a few areas from the bottom that i cant get to, then most of the fab work is done....
Got this done today, strut mounts are welded in and a few sections to replace the missing rails...
Been collecting some more parts for this to get it all moving along, got a set of 560cc injectors nice and cheap, picked up an alloy balancer and pulley kit, got some cam gears on there way. Now the balancer has turned up I can get the bottom end balanced and the bottom can start to be assembled...
