Carbon fibre filler cap? How much?
Its Time to sell.... no one wants to buy a complete car so NOW PARTING
Car can be driven before sale, T-series diff which was locked has let go on the inner driver shaft. Car still drivable.
Car: Toyota ADM sprinter AE86 1983 rolling shell
Color: Yellow
Plate: DRF86T
VIN: AE860006154
Rego: NOV/2011
Km: 198xxxkm on chassis
Crash History: car is straight, no evidence of crash.
Rust: surface rust on top of drivers window; rear hatch top surface rust; underneath driverside qtr window hole size of 5cent; driverside bottom rear sill rust 50cent needs rust repairs.
Bonnet and engine bay sprayed 2 pac Black
Engine bay had rust removed and rear firewall rebraced with 2mm bar and seam spot weld
rad supprt cut for radiator fitment and easy engine removal and install
car will come bare shell roller with rego, number plates not included but can negotiate $2200
SPECS:
Engine/gearbox package:82xxxkm on engine;
sr20det blacktop out of a 180sx stock, NISSAN gasket kit (all gaskets changed except head gasket), Water pump NEW
t28 s15 turbo, s15 injectors, loom, standard computer, Ae86 crossmember s13 engine braket welded
extreme heavyduty clutch NEW
sr20det bell housing rb20det gearbox rear(nice and tight)
modified ae86 transmission mount.
For those not buying the NISMO mounts, i can supply free standard mounts to fit up.
Price: $5500.00
Brand New Clutch Master Cylinder
NISMO clutch Slave Cylinder NEW
Braided clutch line
Price $300
metropolitan drive shaft custom 3in one piece tail shaft to suit above to T-Series Diff paid $550
Price $400
standard s15 dump
3inch front pipe
r34 caralytic converter into custom 2.5 inch piping
2.5 s/s magnaflow resonator NEW
3inch AJ racing s/s Cannon NEW
Price $450
k&n rx3900 filter with HKS s13 intake modded to fit
Price $120
NISMO Engine mount NEW
NISMO Transmission Mount NEW
Price $250
inverted Speedfreak front mount NEW
custom piping
HKS ssq blow off valve NEW
Price $750
Honda Civic 3 core aluminium radiator with fan NEW
DRIFT Fan controller NEW
Price $300
Custom made Oil Catch can with big fittings and wired hosesNEW
Price $120
Fuel:
CARTER lift pump
2 litre surge tank
BOSCH 044 external pump
Price $450
blown T-series locked diff drum to drum; (diff has new bearings and seals)
havent pullede it apart but single spins on passenger side, assuming driver side inner shaft has spun.
$120
perfect S-Series diff
Price $150
BM50 300zx brake booster NEW
s13 sr20det brakes bendix ultimate pads
standard s13 rotors
Tein s13 coilover (unknown spring rate) NEW
CUSCO AE86 camber tops NEW
s13 sr20det lower control arms
blue bird s3 tie rod ends NEW
RA40 tie rods NEW
standard ae86 steering rack
standard ae86 castor rods
Price $1300
shelby sway bars 24mm
price $150
just jap strut bar front
Price $50
TRD blue shocks
Price $150
AJPS springs rear
Price $120
Another Set of AJPS Springs rear
Price $120
Mitsubishi FTO front seats custom made to be mated to standard AE86 seat base(will assist anyone that wants the same mod)
Price $400 pair
IF YOU ARE SHORT, i have FORD XR6 SEATS PAIR ON AE86 RAILS(Sits a bit high) Can be separated (brakets are held by nuts can use on your fords)
$450
Wheels will sell the Wheels once i have a few things out of the way... way too many rims.
I would like to get rid of the shell and engine package FIRST if possible, before i part out the rest.
Prices are negotiable, no test pilots and time wasters.
Any questions Contact via pm or call me on 0430406604
Jhun
MOPAR or no car!
Pm'ed
Its only carbon wrapped... not real carbon fibre.
Pictures for engine gearbox and cross memeber.... here it is.
i'll take the T series diff, when would it be available for pickup?
Would like to get rid of shell first before i start ripping other parts.
Will let you know when it happens.
Jhun
Just engine? What do you want included? turbo? loom? ... you want it bare?
hey bud, did you have all 4 trd blue shocks?
