Results 11 to 12 of 12
Thread: (SYD) DRF86T sr20det now parting
Threaded View
    Jhun
    Girraween
    Default (SYD) DRF86T sr20det now parting
    Its Time to sell.... no one wants to buy a complete car so NOW PARTING
    Car can be driven before sale, T-series diff which was locked has let go on the inner driver shaft. Car still drivable.
    Car: Toyota ADM sprinter AE86 1983 rolling shell
    Color: Yellow
    Plate: DRF86T
    VIN: AE860006154
    Rego: NOV/2011
    Km: 198xxxkm on chassis
    Crash History: car is straight, no evidence of crash.
    Rust: surface rust on top of drivers window; rear hatch top surface rust; underneath driverside qtr window hole size of 5cent; driverside bottom rear sill rust 50cent needs rust repairs.
    Bonnet and engine bay sprayed 2 pac Black
    Engine bay had rust removed and rear firewall rebraced with 2mm bar and seam spot weld
    rad supprt cut for radiator fitment and easy engine removal and install
    car will come bare shell roller with rego, number plates not included but can negotiate $2200
    SPECS:
    Engine/gearbox package:82xxxkm on engine;
    sr20det blacktop out of a 180sx stock, NISSAN gasket kit (all gaskets changed except head gasket), Water pump NEW
    t28 s15 turbo, s15 injectors, loom, standard computer, Ae86 crossmember s13 engine braket welded
    extreme heavyduty clutch NEW
    sr20det bell housing rb20det gearbox rear(nice and tight)
    modified ae86 transmission mount.
    For those not buying the NISMO mounts, i can supply free standard mounts to fit up.
    Price: $5500.00
    Brand New Clutch Master Cylinder
    NISMO clutch Slave Cylinder NEW
    Braided clutch line
    Price $300
    metropolitan drive shaft custom 3in one piece tail shaft to suit above to T-Series Diff paid $550
    Price $400
    standard s15 dump
    3inch front pipe
    r34 caralytic converter into custom 2.5 inch piping
    2.5 s/s magnaflow resonator NEW
    3inch AJ racing s/s Cannon NEW
    Price $450
    k&n rx3900 filter with HKS s13 intake modded to fit
    Price $120
    NISMO Engine mount NEW
    NISMO Transmission Mount NEW
    Price $250
    inverted Speedfreak front mount NEW
    custom piping
    HKS ssq blow off valve NEW
    Price $750
    Honda Civic 3 core aluminium radiator with fan NEW
    DRIFT Fan controller NEW
    Price $300
    Custom made Oil Catch can with big fittings and wired hosesNEW
    Price $120
    Fuel:
    CARTER lift pump
    2 litre surge tank
    BOSCH 044 external pump
    Price $450
    blown T-series locked diff drum to drum; (diff has new bearings and seals)
    havent pullede it apart but single spins on passenger side, assuming driver side inner shaft has spun.
    $120
    perfect S-Series diff
    Price $150
    BM50 300zx brake booster NEW
    s13 sr20det brakes bendix ultimate pads
    standard s13 rotors
    Tein s13 coilover (unknown spring rate) NEW
    CUSCO AE86 camber tops NEW
    s13 sr20det lower control arms
    blue bird s3 tie rod ends NEW
    RA40 tie rods NEW
    standard ae86 steering rack
    standard ae86 castor rods
    Price $1300
    shelby sway bars 24mm
    price $150
    just jap strut bar front
    Price $50
    TRD blue shocks
    Price $150
    AJPS springs rear
    Price $120
    Another Set of AJPS Springs rear
    Price $120
    Mitsubishi FTO front seats custom made to be mated to standard AE86 seat base(will assist anyone that wants the same mod)
    Price $400 pair
    IF YOU ARE SHORT, i have FORD XR6 SEATS PAIR ON AE86 RAILS(Sits a bit high) Can be separated (brakets are held by nuts can use on your fords)
    $450
    Wheels will sell the Wheels once i have a few things out of the way... way too many rims.
    I would like to get rid of the shell and engine package FIRST if possible, before i part out the rest.
    Prices are negotiable, no test pilots and time wasters.
    Any questions Contact via pm or call me on 0430406604
    Jhun
ID:	22203Click image for larger version.
ID:	22204Click image for larger version.
ID:	22205Click image for larger version.
ID:	22206Click image for larger version.
ID:	22207Click image for larger version.
ID:	22208Click image for larger version.
ID:	22209Click image for larger version.
ID:	22210Click image for larger version.
ID:	22211Click image for larger version.
  1. S15 sr20det motor and s14 box syd
    By evn351 in forum Car Parts For Sale
    Last Post: 16th November 2011, 12:10 AM
  2. (SYD) DFT86T ADM AE86 SR20det for sale
    By methodman in forum Cars for Sale (Toyota Only)
    Last Post: 16th June 2011, 12:23 AM
  3. Parting out ae86 sr20det
    By slighten in forum Car Parts For Sale
    Last Post: 8th April 2011, 04:56 PM
  4. [SYD] Parting out 4AGZE sprinter - plenty of good bits!
    By Doylie in forum Car Parts For Sale
    Last Post: 28th February 2010, 09:24 PM
  5. Replies: 9
    Last Post: 7th January 2009, 08:04 PM
