Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: exciting news! tomei poncams for 20v
  1. #11
    Moderator Frak's Avatar
    Jamie
    If These are like other Poncams they will deliver the goods, Tomei actually do put some effort into their cams.
    Yeah Sam, whagt are these 270 vvt proven cams? The only 'local' ones I've used(and others I know have used) were crap and when cam manufacturer was asked questions basically hung p and didn't want to talk anymore....maybe cos their cams didn't deliver!
    Hachiroku since 1994
  2. #12
    Moderator Sam-Q's Avatar
    Endeavour Hills
    From Clive cams, 270/270 with a sivertop VVT pulley. Gains in the mid and over 6000 in the top end. I think they had 9.4mm of lift.
    They cost around $700 a pair I think? I have been annoying one of my friends for his dyno chart, I should do it again. He later went on to run a turbo and make a stack of power with them. I will go and bug him again.
  3. #13
    Veteran slydar's Avatar
    Dimitri
    the good thing about pon cams, especially for 20v. is that they have been made so no timing alterations are needed, theyve been tested, found the best cam timing, and built the cams to be timed like that without needing cam gears.
    i like the idea of supporting local brands, but as you can see the tomei cams arent really any more expensive and im sure A LOT more r&d has gone into them.
    78's
  4. #14
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    slightly OT but is this the same for 16v tomei poncams?
  5. #15
    West
    Looks like a tempting product, however, they appear to have a single 5 valve 4age application, but we know that black and silver 5 valve 4ag have a 5 degree difference in inlet cam timing, so I wonder which these are designed to suit, or if they have an offset dowel pin like toda or what exactly they do.
  6. #16
    Jamie
    The intake is setup to a 120deg peak lift point, so I'd say set up for blacktop.
  7. #17
    Dimitri
    makes sense really, as toda cams are for ST.
    78's
  8. #18
    Jamie
    New info on Tomei site
  9. #19
    West
    From the tomei site:
    "2011 is the year that TOMEI will focus on the AE86 and 4AG engine!"
    Only took 28 years to get on the bandwagon eh.
  10. #20
    Jamie
    Better late than never, that they are still prepared to spend R&D dollars shows the cult status of the car and popularity of the engine. Well done I say.
  1. Tomei - The Engine Specialist
    By sundee in forum Spirited Drive
    Last Post: 27th June 2012, 02:07 PM
  2. Tomei 4AGE 16V Timing Belt
    By PeakingDuck in forum Car Parts For Sale
    Last Post: 22nd May 2012, 01:20 PM
  3. Tomei, BC Coilovers, CAS and more.
    Last Post: 5th December 2011, 09:45 AM
  4. Full race engine Toda, Tomei??
    By damo46 in forum Technical - Questions
    Last Post: 20th April 2008, 05:45 PM
