Jump the FP & Batt pins IIRC. Then the pump will run with the key on/engine off.
That spacer has nothing to do with sealing besides locating the injector properly, instead it sounds like the o-ring could be damaged, too small or compressed (not sealing well). That is, if it IS leaking from there.
Andrew
