the way to do it properly is to build a kit.
if your car is na, you dont really need to relocate the filter, its fine where it is, just put a sandwich plate in.
you want -10 (dash ten) braided lines with "an" fittings. commonly referred to as "speedflow" though that is a brand, and there are others that are good.
for a core. you want setrab, mocal, or serek. all of these you can get from ebay. most of the ebay no name stuff is ok too.
the sandwich plate should be too hard. i think its 3/4" -16. but either way, its the same as a lot of fords.
done like that, youre looking at $400-$500. new a hks kit will be more, and no better.
