going through a lot of stuff that i will never use
beams dry sump plate it bolts up to std pan with 2 scavange fittings welded to plate 150
dry sump belt pulley to keep the std belt ,takes away the pump gears and pulley is put into place 150 with backing
oil cooler setrap 20 row after 200 for this
Fseries disc brake rear end with kaaz lsd this is from GT celica ra40 3000
20v linkages to suit black top and silver top so if any 1 is missing stuff for there 20v i will most likely have them 30 to 50 depends on what you need also have springs etc if any 1 needs there throttles fixed
1 std plenum for beams 150 with throttle plate
std inlet and heat sink spacer for 3sge beams 100 each
20 valve air boxes std factory set ups 100 each
20 v inlet with injectors only 100 each
beams manual ecus 2 of 300 each 1 is 99 the other is 2003
brand new 48mm quad throttles 1300 a set of 4
brand new 50mm quad throttles 1300 a set of 4
20 v brand new springs and brand new spring spacers 10 each to suit silver or black top throttles
injectors 365cc 200 a set
540cc 350 a set
and 750cc 500 a set of 4
beams pistons with rods set have 11,5 to1 and also 11to 1 300 a set of 4 wont seperate
thats about it till i add more all plus postage
