hey man, ive got the same problem atm aswell hey. it seems to run ok when its like 30 degrees or so out, but any less than that and its shit.
ive been advised to check the TPS and yeah also cam timing aswell.
if its not your cam timing it could be the throttle position sensor, i havent had time to check my own out yet.
i just put my bigport into my 86, and all i did was use the old tachometer wire (i think its like black and brown or something) and put it on the negative of the coil. it seems to work ok for me. maybe make sure yours is connected properly?
let me know if you sort out why your car is running shit, i'll do the same haha.
