Results 1 to 10 of 12
Thread: 4age 20v help! runs terrible once hot
    Member whatcamber's Avatar
    Zac
    Northside
    Default 4age 20v help! runs terrible once hot
    Hey guys at a dead end with my sprinter atm all opinions welcome!
    Engine: 20v 4age BT, stock ecu, stock rebuild, standard cams ect.
    Problem: runs like shit when hot
    OK so the story goes start the car in the morning drive out my driveaway down a few streets engine is perfect! Then the engine starts to play up, at first its like a small hesistation or loss of power around the mid range. Once the car has reached full operating temp it runs like shit. Hesitates hard at about 2500rpm almost like it hits a wall missfiring and carrying on, i can barely get up hills. The car has no power at all it does however idle ok (doesnt stall or cut out at idle or when trying to drive). No back firing or black smoke out the back. Revs fine when not underload!
    So things i have replaced:
    Spark Plugs
    Spark plug leads
    Fuel pump
    Things i have checked:
    Benchtested ignition coil
    Benchtest Coolant temperature switch (ecu)
    Pulled apart dizzy
    Played around with ign timing
    Played around with spark plug gaps
    Checked ecu with scan tool - found nothing..
    I have had this problem for awhile not this bad however. The car has been down on power since before matsuri and has slowly gotten worse.
    Any ideas?
    West
    Possibly a faulty temp sensor.
    Possibly associated wiring.
    Zac
    Northside
    I was certain it was that however i tested mine out of the car with my multimeter and it seems fine.. I havent check the wiring though..
    Zac
    Northside
    Also if it was the CTS id expect it to be overfueling hard, the car runs alittle on the rich side but its not shooting out black smoke. It seems to me like a spark/ ecu issue.
    Veteran slide86's Avatar
    Huw
    Hills
    put a clamp on the fuel return line and drive it and see if it improves........ie fuel reg stuck open so no pressure in the rail under load
    I've had this in fwd cars and after replacing the knock sensor the problem went away on one.
    The other turned out to be shit earths, tighten them to be sure. Do you have the check engine light connected because it should flash on when bogging down. Also check you have constant power connected to your ecu because codes can't be retained if you don't.
    In factory configuration there is an earth from the engine lift bracket to the ignitor, adding this helps heaps.
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    I agree with knock sensor being faulty or coolant temp sensor.
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
    Zac
    Northside
    Thanks ill give it a try this weekend
    Moderator Sam-Q's Avatar
    Endeavour Hills
    check the caps in your ecu
    Zac
    Northside
    Added a quick earth from the ignitor to the body and the car drives 80% better! Will grab some thicker wire and proper terminals from work tomorrow. Still has a small miss but car is definately driveable/ driftable!
    Thanks for all the help
  1. 4AGE Team Toyota Australia dyno runs
    By Frak in forum Technical - Articles
    Last Post: 3rd September 2013, 02:08 PM
  2. BNE - 20v trueno part out!!! hot shit!!
    By kaibeecee in forum Car Parts For Sale
    Last Post: 12th January 2010, 01:48 PM
  3. The reason for terrible accident
    By baboo in forum General Topics (No Technical Questions)
    Last Post: 16th June 2009, 03:57 PM
  4. terrible kms to a tank with my 4ac
    By Nic19 in forum Technical - Questions
    Last Post: 21st March 2009, 10:44 AM
  5. 4age dies when its hot
    By boh in forum Technical - Questions
    Last Post: 27th March 2008, 08:28 PM
