Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: Lexcen Polycarb window info
    Veteran McLEVIN's Avatar
    Nov 2010
    Default Lexcen Polycarb window info
    Im after info on how to install polycarb (Lexcen) windows on the 86 3door.
    im looking at getting some made up so is there anything in need to know or do i just get the glazier to cut to the same shape as the orig windows
    also what thickness are you people running, most ive looked are 4mm
    chris
    MOPAR or no car!
    Moderator Sam-Q's Avatar
    Endeavour Hills
    an acrylic window might be a better bet as it's harder and hence more scratch resistant. It will still scratch like crazy though.
    Evan
    Ballarat
    I bought mine from , pre-cut and delivered from Ireland was far cheaper than any quotes I received locally.
    Endeavour Hills
    mcn have always made good products
    West
    It appears their race spec extractors have the wrong pipes connected.
    Veteran timbo's Avatar
    Tim?
    Wild West
    Classic.
    Nov 2010
    thanks guys
    little red spirit not sure what your point is but thanks anyway
    sam i was under the impression lexcen/polycarb/acryclic where all the same.
    also how'd you go installing it, do you use aluminium strips for the hatch?
    MOPAR or no car!
    Evan
    Ballarat
    They are yet to be installed, however when they are I will be using the aluminum strips to reinforce it.
    Veteran slydar's Avatar
    Dimitri
    i wouldnt use acrylic. its a lot more fragile.
    most people settle on 3mm for the sides but 5mm for the rear. the rear will still need to be braced.
    you can install them any number of ways. drilled and screwed or just glued in and using the orginally clips.
    the shape depends on which way you're going to fix them and if you gonna use the orginal window moulds.
    78's
    E-Famous (Remeber your roots)
    What sort of weight would be saved for a coupe just doing the rear quarters and rear window?
  1. FS: ae86 rear window wiper motor and window wiper
    By angelo in forum Car Parts For Sale
    Last Post: 12th April 2009, 04:58 PM
  2. Replies: 0
    Last Post: 2nd February 2009, 09:37 PM
  3. WTB: notch back rear quater window window mouldings
    By shinobi in forum Cars or Parts Wanted
    Last Post: 5th January 2009, 12:09 PM
