Results 1 to 4 of 4
Thread: Throttle Position Sensor Problems
    Nov 2010
    Default Throttle Position Sensor Problems
    hey guys, I attempted to have a look at my throttle position sensor yesterday.
    I took the plug off and connected the multi-meter to the IDL and E2 terminals. It came up with no reading what-so-ever...
    I didn't move the TPS at all, as I didn't want to mess with it seeing as I don't know much about it.
    But I'm guessing it should've at least had some sort of ohm reading?
    While connected I opened and closed the throttle, but still it had no reading.
    I followed instructions from the 4age diagnostics manual and a website i found as well.
    So I'm either thinking it could be that the TPS is broken, hence why I can't seem to get my timing right at all, or I'm not inspecting it right?
    Does anyone have any ideas? Cheers.
    Ps. The engine is a 16v Bigport
    Get some of that contact cleaner on the tps plug and see if that makes a difference...
    If you aren't getting a signal through, your ecu would also throw a code so check them also.
    Nov 2010
    Oh yeah I forgot to say I wired up a check engine light to the ecu which flashes 11 times, and I'm pretty sure that is the code for the TPS.
    I guess I'll give that contact cleaner stuff a try. cheers for your help mate!
    Failing that , new TPS...
  1. Throttle position sensor wanted TPS
    By random in forum Cars or Parts Wanted
    Last Post: 14th March 2012, 01:25 PM
  2. throttle position sensor help
    By 17zon in forum Technical - Questions
    Last Post: 16th September 2010, 06:58 PM
  3. Throttle Position Sensor (TPS) set up??
    By tetsujin in forum Technical - Questions
    Last Post: 13th August 2008, 08:48 AM
  4. How to get Throttle Position Sensor working ?
    By kimilicous in forum Technical - Questions
    Last Post: 24th June 2006, 12:33 AM
  5. Throttle Body Position (gze)
    By slide86 in forum Technical - Questions
    Last Post: 11th May 2006, 10:00 AM
