Howdy sold my ae86 rolling shell took the motor and box a couple of weeks ago was going to keep as spare however old man want it out of the shed
just drop it straight into your rolla
4agze smallport block out of ae101(CAS type)
Microtech LT10s with wiring loom
Garrett T04b turbocharger(rebuilt 500ks ago) with oil lines
W series gearbox with adaptor, 4agze flywheel, 5 puk TRD clutch, fork, shifter, slave cyl, tailshaft
coil on plug setup platinum plugs
ae86 inlet manifold and throttle body
jdm exhaust manifold with turbo dump pipe
hks style external wastegate 10psi spring
lightweight crank pulley
alternator, rwd water pump front half with viscous fan
rwd mounts, box mounts
was all running like a month ago, goes well, car got defected before i really got a chance to give it a good go - to low and too much camber
located gold coast
asking $4000 the lot
may seperate gearbox setup if find someone wants just the motor setup
contact 0424 173 858
i havnt got a ute to move this around so own transport needed
