Car
Ae82 sedan with blacktop 20v (yep the motor faces the wrong way)
Problem
The car is running on 3 cyclinders, appears to be cyclinder 1 that has a problem with being over fueled.
The video attached is after being switched off for around 30 seconds, it just bubbles up and over flows out the top of the spark plug. Cyclinders 2-4 you can clearly see the top of the pistons and they are dry.
I've tried swapping the fuel pressure reg and cranking for about a minute to remove excess fuel from the cyclinders after swapping the pressure reg.
Compression is between 210 and 215 across all cyclinders. And no signs of oil in the water or water in the oil (is a bit of extra fuel though)
After starting to write this, thinking i might try swapping injectors 1 and 3 to see if the problem remains with cyclinder 1. Will get back to you on this, but if anyone else has had this problem or knows where to start that would be great.
Happening since
I've had this car for about 6 months and haven't done anything with it, other than start it up from time to time and let run for a couple of minutes and shut it down. Its always ran a bit shit, but i put in new plugs a while back and it seamed to be better.
I rewired it about a two months ago as the original guy who wired it believed twisting wires and taping it up was good enough.. I doubt it is the wiring as i've wired up around 20 of these in FWD format now...
Thanks for your help guys.
