Results 1 to 10 of 15
Thread: ke70 quad light lamp dimensions
    Junior Member Magyur's Avatar
    May 2011
    Marco
    South Australia
    Default ke70 quad light lamp dimensions
    Car- Flat front ke70
    Part- quad light lamp
    Problem- cannot find dimensions for the round lamps that fit these kits.
    I'm looking to do a quad light conversion on my ke70 and want to fit custom lamps but cant find what size the lamps are. Im guessing that they are about 5-7" in diameter, but this is only a guess. Would anyone be able to link me to where i could find these dimensions or perhaps measure up their own quads and let me know the size of the lamps?
    any help appreciated. (also forgive me if I've posted this incorrectly or in the wrong place, first post and all )
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    5 3/4"
    i personally run these
    with narva +100 (still legal 60/55w) bulbs in the main outside lamps and 130w rally bulbs as a pair of spotlights in the inside lamps. With new wiring, fuses and relays. the light output is comparable with my ba falcon
    what ever lamps you get make sure they are semi sealed so you can replace the bulbs with good ones.
    May 2011
    Marco
    South Australia
    Thanks for that. probably just saved me some moneys.
    Did you run into any trouble with the rewiring and new fuses and relays?
    Lindsay
    Mackay
    i cut the plugs off the original headlights and used those wires to switch the coils on the relays.
    when looking at the plug from the front of the car the top pin is low, the right pin is common and the left pin is high beam (from memory). but id confirm with multimeter/ test lamp before you cut plugs off. if you get the high and common mixed up you will get high beam working properly but low beam will light up both filaments. so you get high beam and super high beam!
    you can get relays with inbuilt fuse holders in the top and get new h4 connectors as well. i run 4 relays, 2 low and 2 high incase a relay/fuse shits itself ive still got lights.
    i'll draw something up when i have time if you like
    May 2011
    Marco
    South Australia
    you've been a massive help (: really appreciate all this.
    if you dont mind a drawing would be amazing. no pressure though man. you've already helped me heaps
    Lindsay
    Mackay
    i might do a drawing tonight when im home and can look at my w/s manual for cable colours. or tommorrow night, we'll see.
    May 2011
    Marco
    South Australia
    no worries (:
    Lindsay
    Mackay
    i just did this for both sides. you will probably have to extend the switch wiring to get to the relays.
    you could do it with just two relays, one for high and one for low but if one relay shits itself then you lose either high or low completely. this way you still have some light.
    if your buying cable from the auto parts store get some thats good for 20 amps.
    fuse selection:
    Amps = power(watts)/volts
    so if you have 55w low beam and your alternator puts out 14.4v (in reality it probably doesn't anymore)
    then its 55/14.4 =3.8 amps so you would run a 7.5A fuse per side for the low beam
    high beam
    60w+60w for spotlight=120w
    120/14.4 =8.3 amps so run 10A or 15A fuse
    if your like me high beam is 60w+130w for the spotlights
    210/14.4 =14.58A so i run a 20A fuse
    May 2011
    Marco
    South Australia
    cannot thank you enough for all this. im gonna be honest and just say that i would have definitely botched up my quad conversion without all this. thanks for your time man. very helpful.
    Lindsay
    Mackay
    no worries dude. happy to help
  1. [SA] Complete Ke70 Flat Front And Quad Light Setup
    By pistol-pete in forum Car Parts For Sale
    Last Post: 19th February 2013, 10:14 AM
  2. Quad light setup ke70
    By 4AGENT in forum Cars or Parts Wanted
    Last Post: 14th March 2011, 08:02 PM
  3. ke70 quad light assembly + 4agte manifold (SA)
    By ae71turbo in forum Car Parts For Sale
    Last Post: 26th May 2010, 05:53 PM
  4. Lhs jdm ke70 quad light assy
    By FAST EDDIE in forum Car Parts For Sale
    Last Post: 19th May 2010, 10:24 PM
  5. WTB: Ke70 quad light conversion kit
    By gumbie in forum Cars or Parts Wanted
    Last Post: 31st August 2008, 09:41 PM
