Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: White smoke from exhaust, your 2cents
  1. #11
    Member johnnyboy_84's Avatar
    Aug 2010
    Qld
    Ipswich
    Older models. Ah.... Touareg gp not current model and older caddys done a couple on older jettas also. it's not really a big issue, was just advising that white smoke is generally coolant. :-) VW is a great brand and they are high quality. Just your occasional lemon like all brands.
  2. #12
    Steve
    This thing about oil only burning blue is a complete myth.
    My last 20v burning thru 4ltrs oil per 500kms never had blue smoke once, it was either dark grey or white.
    Just keep driving brother, as i mentioned watch your fluid levels and 1 day i guess the problem will present itself.
  3. #13
    9x outta 10 the oil being burnt is the valve stems / seals on the 20v. The last one i had an issue with had impressive leak down and compression results. It made real good power too, but just chewed through the oil.
    Monitoring fluids is expected behaviour right?
    In this case run the car up to temp a few times before worrying too much about it.
  4. #14
    Veteran Rice86's Avatar
    Richard
    Liverpool
    Update: smoke is gone now!! worrying is gone
    so drove the car to get petrol, then wheel alignment done, then home just now
    smoke is gone, and does mad skids
    my thoughts: Bad fuel in fuel tank and moisture in tank and exhaust, checked fluid levels and nothing has changed since last time i poured all new oil and fluids
    Thanks everyone, your 2cents has been appreciated
    dose
  5. #15
    Aug 2010
    Qld
    Ipswich
    No prob bud. Glad it's all good now.
  1. Fresh 4age billowing white smoke..!
    By schubey in forum Technical - Questions
    Last Post: 25th February 2010, 07:50 PM
  2. my new 4agte blowing lots of white smoke
    By Nic19 in forum Technical - Questions
    Last Post: 14th December 2009, 06:46 AM
  3. still got smoke issues
    Last Post: 10th November 2009, 10:42 AM
  4. What brand of cigarettes do you smoke?
    By aaron_drift in forum Offtopic Discussions
    Last Post: 25th July 2008, 08:29 AM
  5. White Smoke
    By Pat_AE86 in forum Technical - Questions
    Last Post: 17th February 2007, 07:15 AM
