Results 1 to 4 of 4
Thread: Weak injector pulse
    Default Weak injector pulse
    Hey,
    Problem
    Car won't run
    Happening Since
    4age was installed into a ke70
    Issue
    The ecu appears to be giving out weak injector pulse, it is pulsing, but not enough to fire the injectors. I've seen this in the past and it has been weak earths.. If you manually earth the injectors temporarily the car will start.
    Has anyone else seen this before and is it likely to be a faulty ecu?
    Thanks
    It would appear that i need to get an injector resistance pack thingy which...
    The injectors being used are pink
    Senior Member pt_y2k's Avatar
    Paul
    What 4age are you running and what ecu?
    Bigport for both questions.
  1. No injector pulse on 4agze
    By Sprintn in forum Technical - Questions
    Last Post: 19th September 2011, 06:09 PM
  2. 4age 100kw injector pulse!
    By sic86 in forum Technical - Questions
    Last Post: 5th April 2010, 05:07 PM
  3. no injector pulse 4age
    By cozmic in forum Technical - Questions
    Last Post: 7th February 2010, 10:56 AM
  4. noid test light for testing for injector pulse
    By johnO2 in forum Technical - Questions
    Last Post: 7th August 2008, 10:07 PM
  5. injector pulse
    Last Post: 30th July 2008, 12:28 AM
