Results 1 to 5 of 5
Thread: JDM 4age Bigport loom questions
    Default JDM 4age Bigport loom questions
    Hi All,
    I'm in the middle of a 4age -> ke70 and have realised the loom I've got has been played with a little.
    Just hoping that you could confirm if the following is correct.
    Cut Wires - Near where loom goes into cabin engine bay side
    My guess is these are for the wiper motor control and can be ignored if i retain the ke70 wiring.
    Yellow Plug in middle of Inlet Manifold
    I don't have a plug to connect this into, but I have a brown and yellow wire which has been extended to reach the airbox and an air temp sender has been added in. My thoughts would be it is ok to leave this disconnected and use the air temp sensor in the airbox.
    Between Fuel Rail And Screw holes
    Also what goes between the gap between the fuel rail and the bolts to hold it down? is it just spacers?
    Appreciate your help, i'll attack the wiring later this afternoon
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    Inlet manifold plug I'm pretty sure is a temp sensor. And fuel rail things. There should be like black locating plastic tube bout 10mm long or less to seal it up
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Blue wires,about 4 of them where the loom passes through the firewall are likely wiper motor.
    Yellow plug is air intake temp sensor.
    Yellow with brown to other sensors is air intake most likely,wire code is correct for factory Toyota,later small port is yellow with a black stripe (same as oil pressure).
    Hose port from intake rocker cover feeds to std rwd intake manifold and feeds crank case gas to before the throttle body.
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
    The colours on the ke70 wiper motor match what has been cut so i'm pretty confident this is right... The wiring is now complete and i've got power where it should have and the dash lights up. Will try starting it boxing day
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Definitely wiper motor wires. Edit: and also for the washer motor.
    Air intake temp sensor, like you said, it should be fine to run one in the airbox
    And yeah, you're meant to have 3 little risers that go under the fuel rail.
  1. JDM Loom questions
    By dtour in forum Technical - Questions
    Last Post: 22nd March 2012, 07:26 PM
  2. JDM LOOM QUESTIONS
    By AIROCOBRA in forum Technical - Questions
    Last Post: 28th September 2011, 08:08 PM
  3. Jdm 4age bigport loom
    By Savtec in forum Cars or Parts Wanted
    Last Post: 14th February 2011, 02:27 PM
  4. 4age Loom off JDM Bigport - No lengthening required!!
    By hugh in forum Car Parts For Sale
    Last Post: 15th November 2009, 08:07 PM
  5. Replies: 6
    Last Post: 22nd May 2007, 11:37 PM
