Results 1 to 4 of 4
Thread: Replacing 4age Bigport Timing Belt
    Default Replacing 4age Bigport Timing Belt
    Hi All,
    Followed the guides out there and just wanted to make sure that i've installed the timing belt correctly. I'm re-using the original belt as it doesn't appear to be all that old.
    I lined up the timing marks on the cam gears, lined up the mark on the bottom crank pulley, installed the belt with the writing so i can read it. The tensioner spring appears to be too sloppy and in need of replacing, but given i won't get one today i was hoping to get the car running.
    I've manually assisted the tensioner a little. I realise this isn't the "right" way to do it, but all the spring does is set the tension automatically right?
    I guess the only way to know for sure is to check this video, appreciate your time
    Jun 2011
    james
    oxford
    general area
    England
    The belt tension looks ok.
    My advice with the spring is that if you are at all unsure of it either replace it with a new one
    or remove it completely, it does nothing once the pulley is tightened.
    I had a loose spring jump off and pierce the cambelt once, it was going around and around on
    the belt lol.
    Maybe I can't see it in the video but should'nt there be a mark on the crank pulley that lines up
    with the 'dot' on th engine. The crank orientation looks right though.
    Always turn the engine over at the crank pulley.
    Thanks for the reply.
    The notch on the crank timing gear lines up with the dot on the oil pump, just hard for it to be visible from my phone. I didn't think turning it over by the cam gears would hurt, but it's good to know that is a bad thing. I guess it is the same as turning the engine anti-clockwise, in that it doesn't hurt it, but the belt can skip.
    I'll remove the spring totally, having never done a timing belt before it was best to ask for re-assurance.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Personally I'd replace the spring with a new one.
    Its a bit of reassurance that if the bolt through the tensioner comes loose, the timing belt doesn't jump right off.
    The springs are only a couple of dollars from toyota.
  1. Tomei 4AGE 16V Timing Belt
    By PeakingDuck in forum Car Parts For Sale
    Last Post: 22nd May 2012, 01:20 PM
  2. Greddy timing belt 4age
    By adsrx in forum Car Parts For Sale
    Last Post: 7th July 2011, 12:07 AM
  3. 4age timing belt
    By pogi in forum Technical - Questions
    Last Post: 23rd April 2010, 08:57 PM
  4. replacing timing belt and (tension) idle pully
    By scotty1234 in forum Technical - Questions
    Last Post: 11th June 2008, 10:31 AM
