I've got an rx7 brake upgrade for sale to suit sprinter/xt130just need the brake lines made
Car - ae86
part in question - front brakes, can include rear in anyone has info on how to convert t series drums into rotors?
problem - want complete info on what brakes work, how to fit them ie rx7 conversion and wilwood 4pot upgrade, what size wheels you need for clearance etc.
personal situation - running xt130 struts and thus brakes, and 14" wheels but have 15's on had to in necessary or i dont sell them, want to know if 86 brakes have same mounting as xt130? if not has anyone mounted bigger brakes to xt130 struts etc?
hope thats enough info for some advice
cheers, Josef.
4-ac stock sprinter.
how much that go for? not in the market yet unless its in my price range lol and is it only brake lines needed?
only brake lines yes. and 600 for everything
aight ill get back to ya
i've got bmw 2002 4 piston calipers and unknown vented rotors, calipers are a straight bolt on, have some mounts as factory 86 calipers. will get pics tomorrow
Sounds very interesting!
There's about a million options here, most of which have been discussed in detail (apart from the BMW option above, that sounds new).
- Keep your XT130 struts and use Hilux calipers and Peugot rotors.
- Keep struts and use MX62 calipers and RA60 hubs and rotors.
- Swap back to AE86 struts and buy RX7 adaptors and suited rotors.
- Whatever else your imagination can come up with
As for rear brakes, search Toymods for a thread by GA61XX about discs onto T series drum diffs.
the bmw 2002 calipers as very similar to the volvo 240 girling 4 pot calipers. i'll get pics tomorrow. there is a bit of info on fitting the volvo brakes to toyota struts around the internet.
im not sure what rotors i have, considering the calipers bolt onto the standard struts and fit under 14" watanabes im guessing the rotor size must be close to stock
