I don't have the dimensions on hand, but a couple of points for you that might be of interest.
The AE86 4AGE fan is exactly the same as the 4AC fan, externally. They do however have a different viscosity in the viscous hub for the different engines.
If you are going to run a clutch fan make sure you have a proper RWD water pump. They are taller (stick out further from the motor, run a different pulley also) because they have the correct bearings to support the weight of the fan.
