Results 1 to 3 of 3
Thread: Ae86 4age swap help
    Oct 2011
    Stephen
    Echuca
    Default Ae86 4age swap help
    I have a 1983 ae86 with stock 4ac in it and I'm looking to put an rwd injected 16 valve in it, in doing this is there anything I'll have to change for the radiator or throttle cable? And anything else that will need changing? Cheers
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    A bigger radiator is suggested. Rad from a JDM sprinter will do the trick. Or ppl use ae82 ones. Pretty much as long as the inlets are on the right side. And I think u will need a ke70 throttle able u less u get on made. Hav a google search. There is heaps of info out there on this conversion.
    Just make sure you get all the water pipes and everything with the conversion...
  1. WTB / swap 4AGE AE86 (MEL)
    By AE8866 in forum Cars or Parts Wanted
    Last Post: 17th May 2010, 12:49 PM
