Results 11 to 20 of 23
Thread: The quad throttle onto 16V thread
  1. #11
    Aug 2010
    Sutho Shire
    thanks that answered all my questions pretty much,its way more involved than i thought
  2. #12
    Adan
    Oxley Park
    It is by no means a hard conversion, just needs a little bit of planning.
    I do think a standalone ecu should have preference over this though...or at least be done at the same time.
  3. #13
    Aug 2010
    Sutho Shire
    true,ill keep reading up on it,thanks again
  4. #14
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I'm afraid I'm going have to call you up on that one.
    The ISCV is a very specialised vavle, its not on or off it is infinitely variable. Us such you need the correct ECU to control it. A 16v ECU does not posess the ability to control an ISCV nor can you control it manually.
    An alternate idea is to run a simple VSV off the existing Cold start injector switch to have very basic cold idle functionality.
  5. #15
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    rwd water pipes definitely clear.
    ae71 throttle cable is too short, ke70 cable is longer than ae86 but can be shortened and a new bike cable ferrule fitted. that's the bit on the end and its what I've done.
  6. #16
    Seeing this is an information gathering thread...
    I've heard of people using a 16v ecu with quads... Used a 20v TPS but wired it backwards.
  7. #17
    Aaron
    i think what he is saying is just use the 20v iscv hooked up vacuum wise but not electrically.
    without it plugged in it is open slighlty creating a vaccum leak. i couldnt get my 20v to idle well without it.
    after i connected it up idle sat perfectly at 800rpm without it wired up.
  8. #18
    Adan
    Oxley Park
    yes, sorry this is what I meant.
    Though hooking up to a simple valve would be interesting. On my setup I found that using one 5mm vacuum line out of the canister didnt create enough of a leak to raise the idle much when cold. Im yet to hook up a valve with ports for bigger vacuum lines like the 20v ISCV.
    Using a 5mm line with a simple bleed type valve setup I managed to get my idle like this.
    -Cold, valve closed......500rpm
    -Cold, valve open........700rpm
    -Hot, valve closed........850rpm
    -Hot, valve open..........1100rpm
    Obviously in different weather it varied, and my idle is very rough with the cams so it would be interesting how it would be with stock cams.
  9. #19
    Lindsay
    Mackay
    yep,
    tps side > loom side
    brown > yellow
    Blue > red
    Red > Blue
    Yellow > brown
    there is a really good write up on one of the "other forums" if you want me to post a link
  10. #20
    Aaron
    post the link up so we can all read please
  1. Wtb: Hks 272 cams and quad throttle bodies for 4age 16v small port
    By chrisfindlay in forum Cars or Parts Wanted
    Last Post: 26th April 2012, 03:27 AM
  2. Quad throttle bodies and adapter plate for 4AGE 16V Big port
    By Osaka86 in forum Car Parts For Sale
    Last Post: 16th August 2011, 02:29 PM
  3. Quad throttle RWC
    By jy086 in forum Melbourne & Vic Events and Discussion
    Last Post: 9th January 2010, 04:09 PM
  4. WTB : T3 quad throttle adaptor for 16v
    By ae86hachiroku in forum Cars or Parts Wanted
    Last Post: 5th January 2009, 04:01 PM
  5. quad throttle bodies for 16v 4age
    By Jamie in forum Cars or Parts Wanted
    Last Post: 12th February 2008, 08:48 PM
