Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: The quad throttle onto 16V thread
  1. #21
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    after re-reading that i think it could make a good base for an improved write up. there is a couple things im doing different for example he drills another set of holes in the adapter where i enlarged the existing to 1/8 BSPT and run a vacuum manifold with all quads connected, brakes, fuel reg and map sensor.
    FYI im running 7age, cams and Adaptronic
  2. #22
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Sam, how about drill and tap the #1 and 4 throttle adaptors after the throttle bodies to replicate the OE setup in the AE101/111 for dual supply to the brake booster?
    This would be better for brake booster pressure in comparison to the T3 4x 2mm nipples surely (even with vacuume canister).
    The Blacktop only has a 2mm slot milled from each throttle between the head and manifold for the throttles to provide vac to the Map sensor.
    If you haven't got a blacktop manifold there (or seen one) shoot me a PM and Ill send it over.
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
  3. #23
    Moderator Sam-Q's Avatar
    Endeavour Hills
    good idea slimmer, I will need to find out if this person is going to run map or tps based tuning.
  1. Wtb: Hks 272 cams and quad throttle bodies for 4age 16v small port
    By chrisfindlay in forum Cars or Parts Wanted
    Last Post: 26th April 2012, 03:27 AM
  2. Quad throttle bodies and adapter plate for 4AGE 16V Big port
    By Osaka86 in forum Car Parts For Sale
    Last Post: 16th August 2011, 02:29 PM
  3. Quad throttle RWC
    By jy086 in forum Melbourne & Vic Events and Discussion
    Last Post: 9th January 2010, 04:09 PM
  4. WTB : T3 quad throttle adaptor for 16v
    By ae86hachiroku in forum Cars or Parts Wanted
    Last Post: 5th January 2009, 04:01 PM
  5. quad throttle bodies for 16v 4age
    By Jamie in forum Cars or Parts Wanted
    Last Post: 12th February 2008, 08:48 PM
