Results 1 to 10 of 14
Thread: XT130 knuckles to 86 power steer knuckles - Ball joints different size?
    Mar 2011
    Ali
    Default XT130 knuckles to 86 power steer knuckles - Ball joints different size? EDIT: NOT XT130
    Car: KE70 Wagon. XT130 corona struts, knuckles & LCA's
    Problem: Pulled out the XT130 Knuckles to install 86 powersteer knuckles and the XT130 ball joint shaft is too big (about 2-3mm)
    Question: Do you have to chage ball joints in XT130 LCA's to use 86 powersteer knuckles?
    I tried to force the 86 p/s knuckles on to the XT130 ball joint, and Don't really know, I'm no suspension guru but it looks like it may work if I tighten the hell out of it and force it down to the point where I can get the split pin back through, but am unsure if I should go this path as I'm thinking it will only go so far before the ball joint shaft will just spin.
    Now I was told this set up is XT130 from the previous owner, it may be something else, I was just going on their word as I really I don't know to look iat it.
    The RHS knuckle has R4 stamped into it?
    These are the 86 P/S Knuckles they have R3 and L3 stamped into them.
    Do I have these machined out 2-3mm to take the XT130 Ball joints?
    What do you guys do?
    Mar 2011
    Ali
    So I though screw it I'll just put the XT130 knuckles back in and not worry about the 86 P/S knuckles so I can install my coilovers.....
    Nope, The XT130 knuckles fit over the ball joint but are too big for the tie rod end shaft?
    Where as the 86 P/S knuckles are perfect size for the tie rod end but too small for the ball joint? WTF
    ****EDIT: These where not XT130****
    Veteran timbo's Avatar
    Tim?
    Wild West
    That is odd. I put XT130 LCA's in my car and used my pwr steering arms with the ball joints already in the LCA (looked and felt new) with no issues.
    Mar 2011
    Ali
    Yeah, I'm an idiot! Its tappered...I was comparing top to bottom and thats why they looked 2-3mm different.
    So I had a go at it with a make shift breaker bar and I got the nut down low enough to put the split pin through.
    Not game to drop it down yet, I don't think I'll get my jack out!
    Tim?
    Wild West
    Hahaha, I think we have all had moments like that... I found when I did up the tie rode and ball joint nuts that they will only line up once, turn it too tight and you won't get the split pin through.
    Mar 2011
    Ali
    It definitely was more difficult to do up the 86 p/s arms than its was to do the the XT130's?
    Tim?
    Wild West
    Well the XT arms were a real pain to get off, ened up just bashing them with a hammer and eventually they budged. But doing the ball joint nut up took a bit of strength.
    Mar 2011
    Ali
    Yeah I hear that. The 86 p/s arm sits a bit higher on the ball joint and the Xt130 arm....but yeah i does go on.
    Veteran stahlz_ae86's Avatar
    Paul
    My AE86 ps arms have R7 on them. See last photo in this thread that also may help...
    Paul
    If you have installed ps arms onto the ball joints and you're fitting XT130 struts back onto the ps arms you may find the end of LCA hits the back of the disc/rotor as I did. See the above mentioned thread as I had to make custom knuckles to fix the issue. Ball joint hole is in a different spot on the 86 arm to XT130 arm.
  1. SWOP--jdi knuckles for pw steer knuckles
    Last Post: 19th November 2012, 12:18 AM
  2. WTB XT130 LCA's & AE86 Power Steering Knuckles (W.A)
    By HILTZ in forum Cars or Parts Wanted
    Last Post: 16th November 2012, 12:51 PM
  3. Replies: 18
    Last Post: 5th December 2011, 11:48 PM
  4. XT130 LCA's brand new nolothane bushes ball joints
    By jakel in forum Car Parts For Sale
    Last Post: 20th February 2011, 10:51 PM
  5. Shortened XT130 Knuckles
    By KENut in forum Car Parts For Sale
    Last Post: 29th July 2010, 11:07 PM
