Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Making My Own Twin Drift Pipes
    Member chrisfindlay's Avatar
    Nov 2011
    Christopher
    Queensland
    Tewantin
    Default Making My Own Twin Drift Pipes
    Need help with ideas to make this work!
    Ok so early this morning (Sneaky time when it was still dark) I drove to my local Exhaust Work Shop, walked around the back, opened the large bin to find a 6" long 3" diameter straight Exhaust Cutoff, and two 6" long 3" Diameter curved Exhaust Cutoff's.. And my plans are to make my own twin drift pipes..
    My Ke70 is already running a 3" exhaust - Single pipe, but I want to cut it off about 8" from the rear of the car - Leaving me with a 3" exhaust running almost to the end of my keto without an exhaust tip..
    I was wandering how I would go about making my own pipes though (How would I cut and weld them to fit)
    My plan is just to cut the left curved pipe at roughly a 60 degree angle, going from the rear centre position of the pipe, across 60degrees to face the right hand pipe, which I would do the exact same cut to but on the opposite side, leaving the cuts facing each other, and leaving two 1.5' halfs at the end, and a full pipe at the beginning..
    Then I want to weld the two cuts together, so that the pipes are joined leaving me with a 3" tip, running to two twin 3" pipes.. And then welding the single 3" end, to my 3" Straight pipe, and then my 3" straight pipe to my 3" cut off exhaust.
    Looking something like this I guess....
    Obviously there wouldnt be a gap in the end of the two pipes facing the exhaust, I just drew it like that, so you could see what my plan was for the angles...
    Would this work? Has anyone done anything similar, and does anyone have any better ideas? Thanks.
    Veteran johl's Avatar
    Johl
    3 inch is huge for a ke70 to begin with. i dont think you will get any good answer to this question. you will just have to wing it and make a few cuts and see what you have to do to make it work
    Timmy D
    North
    just have a crack
    start cutting and eye ball it
    try your best to make the fit as good as possible to make welding it much easier
    JJ
    Senior Member Vaughn's Avatar
    Vaughn
    Sunshine Coast
    Chris 3" is massive for a ke..... it will look s13 spec (no offence) but at the moment for the 4k it isnt going to do much..... If you get your smallport running i would suggest 2.25" And im pretty sure your green ke has a 2" or less on it
    Just another Muppet
    Nov 2011
    Christopher
    Queensland
    Tewantin
    My ke is running 3" and ill make it work, just you wait..
    Nov 2011
    Christopher
    Queensland
    Tewantin
    Cheers bud, going to weld up the tips tomorrow, Ill use an oxy and a coat hanger as filler wire
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Unless it's turbo, 3" is too big.
    Veteran stx-16's Avatar
    Tweed Heads
    LOOOOOOL
    you play halo?
    add me GT: samnbhnc
    Veteran Rice86's Avatar
    Richard
    Liverpool
    DO THIS WITH 2" or 2.5" pipes, will sound much better
    make sure this is only for track use as it is a stupid size pipe for the street and even for a carby on the track
    it will be loud, but wont be a pleasant loud like a sr20det with 3" straight pipe
    make video of this when your done =D
    dose
    Timmy D
    North
    i pray your joking.....
    3 inch on a 4k will most likely make less power than a 2 or 2.25 inch, its to large so the gasses will get stagnant and hang around
    JJ
  1. Blast pipes/drift pipes . . . 2.5"
    By AE86 Spoontah in forum Car Parts For Sale
    Last Post: 3rd July 2011, 04:11 PM
  2. drift pipes ther twin 2 and a half inch
    By chaff in forum Car Parts For Sale
    Last Post: 9th January 2010, 03:49 PM
  3. Twin 3.5 Drift Pipes - Stainless, brisbane
    By NIZLAH in forum Car Parts For Sale
    Last Post: 21st September 2009, 10:05 PM
  4. Hot twin pipes exhaust
    By klusio in forum Car Parts For Sale
    Last Post: 15th July 2009, 09:42 PM
  5. Twin Pipes
    By Mr Fujiwara in forum General Topics (No Technical Questions)
    Last Post: 15th June 2008, 11:12 PM
