Results 1 to 2 of 2
Thread: Re-drilling Castor Arm into LCA?
    Andrew
    Lenswood
    Default Re-drilling Castor Arm into LCA?
    Hey guys.
    Been looking for ways to move, re drill etc.. my castor arms for more lock. so was thinking. If i re-drilled the castor arm holes to up further towards the crossmember, would it effect handling, alignment that much?
    Thanks,
    Andrew.
    Senior Member Deeken's Avatar
    Jan 2011
    Deeken
    Port Macquarie
    Would you mean drilling the castor rod holes in toward the xmember more? ie not moving them "up towards" anything, but rather moving both sides in closer to the centre of the car?
    Guessing this is to let the inside of your wheels to clear them more?
    Also, moving them in towards xmember is going to increase the stress on them alot more.. also would be bending the castor rods inward more aswell..
    The best idea i have would be increasing the length of the lca as to move your wheels further out away from the castor rods..
  1. re-drilling rotors
    By MR86ER in forum Technical - Questions
    Last Post: 21st February 2011, 07:48 PM
  2. crossmembers, diff gears, LCA's, powersteering racks, castor rods
    By hachi_dk in forum Technical - Questions
    Last Post: 16th August 2009, 09:47 PM
  3. castor arm question
    By scott_22 in forum Technical - Questions
    Last Post: 13th July 2009, 04:34 PM
  4. Wheel Re-Drilling
    By gumbie in forum Brisbane & QLD Events and Discussion
    Last Post: 10th May 2009, 03:47 PM
