Ladies and Gentlemen,the time has come to sell Lloyd smiths Ex Falken V8 Drift car
This car was completed in 2010 and has seen well over 30 drift events in the past 24 months and has been nothing but reliable making any and every event possible on the calander, You think the Motorfix V8 corolla is good, wait till you see/hear/drive this
Currently has 270kw and 700nm at 7400RPM
Notable achievments for lloyd in this car include
2010 Tas drift series 5th overall on debut year
2011 Power cruise Burnout comp winner (against 500hp big block burnout cars)
2011 World time attack 5th place qualifying
2011 Tas drift series 2nd place overall
Car article in Performance imports 141
Article in rereleased Drift battle magazine
Few snippets of action on Wreckem 2010
The full build thread is available to view here
Full specs as listed below
AE71 Toyota Corolla Chassis- Slant front
ENGINE
AZcustom 8 litre trapdoor sump
Factory Rods
ACL race series bearings
Custom ROSS pistons (once off made, Moulds were sent of head and block for design in the US of A)
Total seal Piston rings
Cometic Metal head gaskets
ARP head bolts
Head ported and polished
1mm oversized valves
Kelford Valve springs
Kelford 286 degree cams
Powder coated rocker covers
4age Blacktop Individual throttle bodies with custom velocity stacks/airfilters
Custom vacuum plenum with in car idle control
7MGTE 440cc Injectors
Bosch 070 Lift pump
AZcustom 3 litre surge tank
Bosch 044 feed pump
Azcustom equal length extractors ceramic coated chrome feeding twin 2.5" side pipes
AU falcon radiator
AZcustom header tank
OEX 16" thermo
AZcustom Catch can- mounted inside car
B&M oil cooler
Grex thermostatic oil filter housing
Power steering cooler
S13 PS pump custom mounted
Haltech PS200 ECU
Ba falcon ignition coils
New genuine rotor buttons, dizzy caps, leads
BKR6EKUB sparkys
Driveline
CRS Bellhousing
CRS lightened flywheel
Xtreme 260mm drift clutch
Rebuilt toyota R154, new syncros bearings seals etc
PPG Chromoly 3-4th gear selector
Custom 1 piece tailshaft
Locked Hilux diff- Multiple ratios available, 4.11 atm
Front Suspension/Brakes
- S13 crossmember moved 30mm forward compared to where holes usually line up for more caster without wrecking inner LCA bushes and no chance of binding due to the steering rack coming forward
- S13 steering rack with power steering
-NP offset rack spacers
-S13 lower control arms notched and boxed in
- Inner LCA pivots on crossmember re-drilled 30mm higher
- D-Project solid steering rack bushes
- JJR tie rod ends
- s14 tie rods
- BC Racing S14 front coilovers with 8kg/mm or 7kg/mm springs avalible
- S14 knuckles and hubs (5 stud)
- NP modified knuckles 15mm out 18mm in
- Modified strut tower tops to position strut tops further backwards and out
- SuperPro inner LCA bushes and caster rod bushes
- Custom front swaybar
-S14 front brakes
Rear Suspension/Brakes
BC Racing AE86 rear setup with 6kg/mm springs
- Custom equal length 4 links with SuperPro bushes
- JJR panhard rod
- Move panhard rod pivot down on diff
-Custom traction brakets
- RA60 swaybar with SuperPro link and D bushes
- R32 gtr rear rotors and calipers
Interior
Custom aluminium dash,
Speco gauges- Oil temp,oil press,water temp,Tacho,speedo,Fuel,
Gktech steering wheel
Pull type hydro handbrake-Custom extended handle
Snap-ON Shifter
Bride Style Fixed back seats
ERG 5 point harness’s
Azcustom Cams approved rollcage
Exterior
Custom 30mm widened front Guards
back doors welded shut, all flush
Flared rear gaurds
Bonnet cut out to allow ITBs to stick out in the fresh air
Currently Painted Falken Racing team colours- Obviously you would want to change this (can possibly be done for new buyer)
Wheels
17x8 front
17x8.5 rear. Comes with 2 sets
BBS style wheels
fitted with falken tyres... DERRRR
All engine work carried out by Tasmanian Engine Reconditioning
Custom Fabrication Completed by AZcustom
Powder coating by Hi octane Coatings
PIctures and videos,
Now a simple google and youtube search will result in literally hundreds of pics and vids so feel free to do some looking around,
Some of the better ones included below
PRICE
Currently chasing $22K ONO With A1 Bodywork , as mentioned can be resprayed in any desired colour, Aus and possibly world wide shipping available,
seen this run at winton ..... off tits
2 in the pink 1 in the stink
