Results 1 to 5 of 5
Thread: broken engine block.....fixes?
    Adan
    Oxley Park
    Default broken engine block.....fixes?
    Hey everyone,
    Im currently stripping an ae92 which got written off.
    This morning I finally got around to starting to take the engine out.
    The top 2 bolts which mate the block to the gearbox were only finger tight, once I loosened them I realised that there was a bigger problem.
    2 or 3 of the chunks of the block which the rest of the bolts go through have broken off the engine block. So really there was only the top 2 and bottom 2 bolts holding the engine and geabox together.
    I think it was a combination of dead engine mounts and the hit from the side which did it (car was written off, whole d/s strut tower was moved).
    Has anyone ever had these rewelded on? Or even encountered this problem?
    I just need to decide whether its worth taking the engine out now, or just scrap the whole thing...
    Gunner
    Build up some weld, machine, and drill and tap. only real way to do it that i konw off, alot easier with alloy blocks though.
    Adan
    Oxley Park
    The whole flanges have broken off, plenty of meat to leave the holes as they are.
    But if its something which people have done before, I dont mind chucking the welder at it. I still have some cast iron electrodes somewhere...
    Gunner
    I've done it to alloy blocks never an iron block though, cant see why it would cause any issues, apart from it being shit to weld.
    Adan
    Oxley Park
    easy as, engine will come out then
  1. My Smallport/Bigport mix and match motor swap & broken engine vid
    By jet111 in forum General Topics (No Technical Questions)
    Last Post: 9th July 2009, 02:39 PM
  2. 7a Engine Block Wanted
    By Cameron_Datto in forum Cars or Parts Wanted
    Last Post: 28th June 2008, 04:58 PM
  3. Ghetto fixes
    By snake in forum Offtopic Discussions
    Last Post: 5th May 2008, 02:34 PM
  4. Removing broken bolts from the block
    By ae71 in forum Technical - Articles
    Last Post: 2nd August 2006, 11:58 PM
  5. Broken engine mount bolts
    By works510 in forum Technical - Questions
    Last Post: 16th July 2006, 09:03 PM
