Results 1 to 7 of 7
Thread: HELP ID struts, knuckles and LCA's
    Mar 2011
    Ali
    Default HELP ID struts, knuckles and LCA's
    Car - ke70 wagon with ae71 x-member conversion with mystery strut, LCA, disc's and hubs?
    previous owners said that it had "XT130 Struts, LCA's and knuckles"
    motor / part in question - Struts, LCA's, hubs & discs.
    problem - Help identify
    occurs/started when (if applicable)- when installed new coilovers with 86 P/S knuckles - LHS ball joint was fucked so I tried to replace the ball joint and the early corolla/corona BJ145/217 was too small WTF>?
    personal situation (if applicable) - one confused mofo who just spend 30mins at repco struggling with the "parts interpreter" trying to ID my ball joint with no luck....
    -So these struts, knuckles and LCAS were installed on my KE70 wagon with AE71 xmember.
    I was told they were XT130, but I don't believe they are.
    They do have bigger hubs that suit XT130/MA61 stub axles as I have had the hubs and discs on my new XT130/coilovers, but the spacing for the knuckles is different to XT130/ AE86/ AE86 p/s knuckles.
    Also on the LCA's, the ball joints are bigger then the early corolla/corona (XT130/ XE7X/ AE86 BJ145 (or TRW JBJ217) ) by 2mm.
    I just tried to fit a BJ145 in and it was too small for the LCA...
    The Ball joints look identical to a BJ145 but on verniers the BJ145 is 2mm smaller in circumference....WTF
    I've got some kind of frankinstein front end in this thing.
    Can anyone help out to identify what the hell i got here?
    My first hint was when I put my XT130 coilovers in the AE86 P/S knuckles would not fit on the ball join properly.
    I ended up forcing them on with a breaker bar and am now regretting doing that as I think I'm going to have a fuck off hard time undoing this!
    LCA Pic up soon
    Mar 2011
    Ali
    Ventilated disc and hub
    Mar 2011
    Ali
    Just compared the MA61 hubs and disc's I have for my coilovers to these and the hubs are identical but the discs are slightly bigger than the MA61 discs?
    Mar 2011
    Ali
    Just found a ball joint listing for early Supra/Cressida BJ314 or BJ232 (same) says 44mm OD. Thats the right size.
    The early corolla BJ145 measured up 42mm OD...
    So I guess that sort of narrows it down a little.
    Any one ever heard of some kind of either Supra or Cressida strut, knuckle and LCA conversion done on corolla before?
    Mar 2011
    Ali
    So I came across this useful site:
    In it it lists all the toyota's that use the same wheel bearings as MA61 and I cross referenced that agiainst ball join catalogue
    So that narrows it down to Cressida mx32, mx36, mx62, mx73 or Supra ma61 and the disc's look different to the MA61's that I have compared them to..but I really should measure them...
    Veteran stahlz_ae86's Avatar
    Paul
    Calipers look like they could be MX62 Cressida.
    I'm about to do the RA60/MA61/SA63 etc. 258mm x 20mm vented disc upgrade onto my xt130 struts, with MX62 caliper and the photo looks like the cressy one's I have. The ears on the strut where the caliper bolts up, what's the hole centres?
    Mar 2011
    Ali
    I tried the calipers on my XT130/coilovers and the spacing is different...
    I'll measure it up and get back to you.
  1. Replies: 18
    Last Post: 5th December 2011, 11:48 PM
  2. Sigma lca,s and ae86 p/s knuckles
    By nichy in forum Cars or Parts Wanted
    Last Post: 10th August 2010, 01:52 PM
  3. VIC: standard ae86 struts/lca/knuckles
    By kebabs in forum Cars or Parts Wanted
    Last Post: 24th October 2009, 06:57 PM
  4. ra60 struts/ 86 strut inserts / t18 struts / steering knuckles
    By driftke70 in forum Car Parts For Sale
    Last Post: 19th August 2009, 06:44 PM
  5. S13 Hubs/Knuckles + Cressida LCA's
    By paulie in forum Car Parts For Sale
    Last Post: 17th October 2007, 05:12 PM
