Results 1 to 7 of 7
Thread: Track car water cooled brakes
    Senior Member mrbigport's Avatar
    Craig
    Canungra
    Default Track car water cooled brakes
    CAR - KE70
    Motor - 4AGTE (300+whp)
    USE - Track only
    Question-
    hey guys, I'm toying with the ideas for brake cooling on my KE70
    I'm currently running jdm 86 vented disks and calipers and due to wheel size (13x7) cant go jumping to bigger disks without it costing a small fortune in wheels and semi-slicks.
    what are peoples thoughts on the pros and cons of:-
    positive pressure brake ducts - forcing air from the front of the car onto the disks
    negative pressure brake ducts - drawing heat away using a venturi style duct
    water cooling - using either water mist in a positive pressure duct or water mist injected through the center of the vented disk vanes and allowing the air flow of the rotating disk to draw the water through.
    any other ideas would be really appreciated.
    Craig
    4agte KE70 263.6whp
    QR Sprint Circuit 1:02.9
    QR Sprint Circuit 60.7 (turbo)
    QR Clubman Circuit 1:06.41 (first outing NA)
    QR Clubman Circuit 1:02.77 (turbo)
    http://www.ae86drivingclub.com.au/fo...ustom-Stickers
    full colour windscreen banners from $45!
    Gunner
    why not just match the pads and fluid to the temps you're getting?
    Craig
    Canungra
    I'm already doing that to an extent, but ultimately the higher the temps the higher the cost of consumables (pads and rotors) and also the more frequently they will need to be changed.
    Thus if i can keep the average temps lower then the longer they'll last both overall and in a session.
    4agte KE70 263.6whp
    Gunner
    Ok fair enough, I'd start at positive pressure ducting, then I'd go from there. I'd be worried about over cooling with the water cooling.
    Craig
    Canungra
    something like this....but I'm thinking I'll have a pyrometer attached to the back of the pad and the water cooling wont be armed until say 300deg and then it will activate while the brake lights are on thus eliminating the chance of over-cooling
    4agte KE70 263.6whp
    Gunner
    It's a cool kit, but I think on a corolla it would be overkill, and you would be better off spending money else where. I've seen 400kw evos overcool the brakes just from ducting, hence why I think its a bit of overkill for corolla.
    But dude it's your carm if you want to do it, go for it, only one way to see if it is a viable investment.
    Mar 2011
    Dave
    SE suburbs
    Ducting number 1. Feed it from the front splitter with some small scoops, and pump it into the middle of the rotor.
    If that doesn't do much, then look into water spray.... just check it's allowed at the track you drive at.
  1. Replies: 54
    Last Post: 7th July 2012, 11:46 PM
  2. 4AGTE 20Valve track car Fast fours feature car :)
    By ke70drift in forum KE70 / AE71 Owners Forums
    Last Post: 27th May 2012, 11:18 AM
  3. [QLD/NSW] WTB: Car trailer for track car
    By keiichi in forum Cars or Parts Wanted
    Last Post: 22nd October 2010, 06:42 PM
  4. (SA) Cheap ADM 86 for project car or track car use...!!!
    By dasini in forum Cars for Sale (Toyota Only)
    Last Post: 13th April 2010, 03:15 AM
  5. Nitro RC Race boat .18cc water cooled RC boat
    By jimbarno in forum Other Items for Sale
    Last Post: 7th March 2010, 08:49 PM
