Hi Everyone,
Issue
I need to wire up my in tank fuel pump
Happening since
My ke got a 4age and needed an EFI pump
Concerns
I've sourced a bosch fuel pump and the strainer, cut the pickup for the tank and it sits nicely now at the bottom of the tank. Had to bend the piping a little to make it sit flat, but that is done. I've got cable ties holding the pump exactly where i want it.
I've sorted out the FOC relay as i hooked up an external pump initially to start the car and I've got wires now connected to the pump, but i need to get it through the round circular bit which bolts into the tank. I'm a little hesitant to run wires through for fear of petrol getting in between the wire and the insulation and the relay coping it.
What is the best way to seal the wiring from the fuel inside the cabin? And is standard wiring ok to use inside the tank.
Thanks
