Page 51 of 55 FirstFirst ... 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 LastLast
Results 501 to 510 of 546
Thread: 2AZ powered 86
    West
    Front left outer wheel bearing failed cause water got in. All fixed now.
    West
    West
    Did 14.39 on the 1/4 tonight.
    West
    West
    The day i bought it.Click image for larger version.
ID:	37461Click image for larger version.
ID:	37466Click image for larger version.
ID:	37465Click image for larger version.
ID:	37464Click image for larger version.
ID:	37463Click image for larger version.
ID:	37460Click image for larger version.
ID:	37458Click image for larger version.
ID:	37459Click image for larger version.
ID:	37462Click image for larger version.
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    It has come a hell of a long way since then. Great work on the build and now getting to enjoy the fruits of your labour.
    Sent from my GT-S7275Y using Tapatalk
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
    West
    Hey thank you.
    Small update to make. I just fitted some 150mm trumpets. Definitely added some torque.
    Inlet now about 400mm from valve top.
    West
    They added a little down low but nothing up top upon dyno testing.
    Now going to different 48mm throttles with upstream injection.
    Will report back once dynoed and see how it goes. It seemed to make peak torque then just die off quickly after, so I think there's more power there with more air because this motor does not have an aggressive stock cam and Id expect another thousand revs of separation between peak torque and peak hp than I currently have.
    West
    Have been working on this.
ID:	37811   Click image for larger version.
    Mar 2011
    Ali
    Looks amazing man!
    If after you have it all set up, are you run another 1/4?
    Let me know if you do, Willowbank's just down the road from me, I'd love to hear this thing on full song!
  1. The 4age powered Toyota 86
    Last Post: 18th December 2012, 11:36 AM
  2. 2AZ COP's - JJR recliner - rear shocks
    By biggo in forum Car Parts For Sale
    Last Post: 11th August 2012, 11:15 AM
  3. WTB: coilpacks + plugs off 1NZ, 2AZ or 1ZZ
    By Sam-Q in forum Cars or Parts Wanted
    Last Post: 15th February 2009, 08:09 PM
  4. 13b/13bT powered 86's?
    By jarryd in forum Technical - Questions
    Last Post: 30th November 2007, 01:01 AM
  5. Calling all CA18DET powered 86's
    By lowau in forum General Topics (No Technical Questions)
    Last Post: 21st August 2006, 11:06 AM
