Been doing a bit. Its mostly wired now, thanks to Medicine man for the help. I need to chase a few small parts. Otherwise its coming along nicely.
Now Ive made a few more strides towards finishing this. I have adjusted and fitted the gaskets to the throttle bodies. Now they all sync correctly and stop at the right place, and I shouldnt need to remove them again from the manifold.
Ive put oil in the diff and rotated the axles to lube the gears.
Ive done up the cooling system under the car, I have to strap in the efi pump and connect the wiring but its all there as far as pumps, surge tank, and lines and filter.
Ive purchased a new fuel reg from Tomei for it. Should arrive soon. Then everything is new in the fuel system and I can expect perfect fuel.
Rear brakes are rebuilt completely. Brakes are bled, so thats clutch brakes and accelerator all connected.
Once I mount the efi pump Ill adjust the drums, and do up the last couple of bolts on the handbrake cables and it can be rolling again.
I might take the chance to run the wiring from the fuel pumps to the front of the car for Justin to connect to.
Fck yeeah
this is amazing,how havnt I seen this before now lol
Rhonda the F20c powered Panelvan
http://www.ae86drivingclub.com.au/fo...20c-powered-E7
When you cant find shit you make it.
T3 sell those panels as well and pretty cheap as well
My AE86 4AGZE to 3SGTE thread
Check out my sale threads for 4age and ae86 parts
http://www.ae86drivingclub.com.au/fo...nd-going-Turbo
http://www.ae86drivingclub.com.au/fo...ything-must-go
Sponsors
Platinum Automotive Smash Repairs - Padstow
Rear trim panels look great mate, very similar to those ones I bought off you ages ago, still use the back seat ones, just sprayed them black. The boot ones look fantastic, might have to hit you up for a template when you grab that hatch lock.
If you like em there, check em out with the vinyl on em:
Got my 6x9 alpines in the post. Ill have to find some decent 4 inch speakers for the dash locations. I dont want to cut my door skins for 6 inch speakers.
I really do need to come grab that lock off you mate, and also, I have the templates and your welcome to use them. Better still Bring your car over some day and we can use my workshop to fab them up. Its easy to come up with the curves on my 10 inch disc sander. Plenty of spare vinyl too.
So I have now made the 6x9 boxes.
Picked up a hks pod cheap on ebay.
Have also got the parts I need to finish the wipers. Josh (Brilgo) was awesome enough to drop past yesterday with his ae82 sleeper and gift me some of the 1/4 window clips. Someone was trying to sell me three clips for $90 so its awesome to be given them. Thanks a lot mate. I can now finish off the left window and moulding.
Have received the oil sender relocation hose in the post also. Looks dope and will sit where I planned.
Looking at finishing off the dash, belts, trim and then seats soon. Also will vinyl wrap and install the actual speakers to the 6x9 boxes, and wire the speakers up plug and play at the stereo ala what Justin did with the power feeds.
Need a few bits, reverse switch for a w57, the pair of number plate lights, plastic front gaurd inners, wiring for the parkers, stock radio antenna with cable, and door locks with a key for em. Anyone? I have a lot of spare parts to trade if anyone needs trim or bits and pieces.
