works perfectly.
The plu sits at a slightly different angle, but I have one in my car right now.
Will this work?
works perfectly.
Okay, I'm just having trouble lining it up. When the bracket is done up I can't get the bolt into the thread of the alternator. Get what I'm saying?
will making everything loose and then put in that "bolt" into the thread then tighten everything up work?
sounds like you just have to force it to align up
dose
NopeIt sits a good few mil off. Confusioooooooooooooooooooooon!
I tried using "the force" but it wasn't on my side today.
You using it with a rwd alternator bracket?
I am, and it went in no trouble. Maybe post a pic of what you mean...
THAT! Could be the problem. Posting pics now.
So when I do the two bolts up the alternator lines up like this;
and when I do up one bolt and the alternator, the 2nd bolt lines up like this;
Sorry for the bad photo.. I'm thinking about just drilling it out to make it fit. Dodgy, but I do live in Nerang.
Just elongate the hole on the bracket, big washer no one will be none the wiser..![]()
